586,005 active members*
5,022 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > PWM Output Voltage Drops from 100%
Results 1 to 7 of 7
    Jul 2019
    I am using Mach3 to control one of those cheap 500W Chinese spindles via a uc-100 and Gecko 540.
    With the spindle disabled at the VFD I am getting 0 to 10 volts at pin 8, proportional to the spindle speed percentage as set in Mach3. Just like you would expect.
    If the spindle is then enabled at the VFD, the output voltage drops to about 5.8 volts on pin 8, and the spindle runs at only about 70% speed even though Mach3 is set to 100%.
    Now for really strange part.......
    If I just take the tip of a screwdriver and just touch pin 7 on the Gecko, the voltage jumps up to 10v and the spindle speeds up to 100%. If i then stop touching pin 7 the voltage drops to about 9 volts.
    Similarly, If I touch pin 8 with the screwdriver, the voltage drops to about 2 volts, and returns to about 5.8 when I stop touching it.
    The spindle works fine when controlled locally at the VFD over it's entire speed range, so motor loading doesn't seem to be the problem. I have also verified that all connections are tight and the local speed control pot on the VFD is disconnected when hooked up the Gecko. Changing the settings on the Spindle Pulley in Mach3 makes no difference.
    I sure would appreciate any suggestions relative to the source of the problem and the means to fix it!
    Thanks In Advance for any help!
    15362
    Re: PWM Output Voltage Drops from 100%
    Quote Originally Posted by JohnT1 View Post
    If your spindle only has 2 wires like in the snip then you don't have a VFD Drive, your spindle is a DC motor and driven by a DC drive
    It sounds like you have a Ground problem as pin 7 on the G540 is GND
    Your PWM or 0-10v has to connect through where the pot is wired the other connection is just the On/Off
    Mactec54
    Nov 2009
    Sounds like noise. I am having a very similar issue but with a different controller (Pokeys57CNC). With the spindle not running I can vary the speed in Mach3 and see the frequency on the VFD change and go all the way to 300 (Max for my spindle). But if I start the spindle the frequency drops to about 270 and if I measure the voltage it is somewhere around 8v. Ordering an EMI filter and some ferrite cores to see if that fixes my issue.
    15362
    Quote Originally Posted by ericvic View Post
    He does not have a VFD Drive, this is a totally different setup than yours, if you have a VFD Drive
    Correct Grounding and Shielded cable termination in your case has to be correct if you have a noise problem
    Mactec54
    Nov 2009
    He stated
    so how is that not a VFD drive?
    15362
    He stated so how is that not a VFD drive?
    Because he is confused as to what he has, he does not have a VFD Drive
    Mactec54
    Nov 2012
    1267
    Your problem is not noise. Your problem is that the junky DC motor controller (I had one of those in the past) is not properly isolated from the AC mains. That's why everything changes when you touch the pin with a screwdriver. It is a very good way to blow up your Gecko, UC100 or the PC if you are unlucky.
  1. Plasma voltage drops when cutting
    By xyz-cnc in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-10-2019, 12:13 PM
  2. Output voltage from Output Board seems to be quite low?
    By cdfleischmann in forum PlanetCNC
    Last Post: 07-25-2018, 12:18 PM
  3. Kanalog no DAC output voltage
    By MicroTools in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-14-2016, 09:29 PM
  4. Output 2 voltage
    By Claytonc in forum DIY CNC Router Table Machines
    Last Post: 03-18-2012, 11:48 PM
