584,833 active members*
5,582 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Kitamura Minisuper 300 Retrofit - Part2
    First, some pictures...
    First some pictures...
    Re: Kitamura Minisuper 300 Retrofit - Part2
    Nice work.
    Many thanks :-)
    Now the machine is abandonated for some weeks. Mounting the slidecovers I noted that some parts are missing.
    Someone has changed the position of the limit switches, to get a little bit more travel. But of this reason he take out the slidecover.
    I had a look to some videos on youtube, bit nothing. I can´t localize the original part, because its under the table cover.
    Now I redesigned the missing piece and sent it to laser cutting and bending. If I get the pieces, I will weld together and paint them.
    Its a slide cover to cover the Y-Axis and the front part of the lower case.
  1. Kitamura Minisuper 300 Retrofit
    By seahawkibiza in forum Kitamura
    Last Post: 03-12-2019, 03:46 PM
  2. Kitamura MyCenter 1/485 - ground up rebuild and retrofit
    By t_hum in forum Vertical Mill, Lathe Project Log
    Last Post: 01-31-2019, 05:26 PM
  3. Kitamura Fourth Axis Retrofit?
    By CNC Biker in forum Want To Buy...Need help!
    Last Post: 04-09-2014, 04:26 PM
  4. Kitamura Fourth Axis Retrofit?
    By CNC Biker in forum Uncategorised MetalWorking Machines
    Last Post: 04-09-2014, 04:23 PM
  5. r2 part2
    By Thomas Doll in forum Uncategorised CAM Discussion
    Last Post: 06-22-2011, 01:27 PM
