585,753 active members*
4,210 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > I have a Novakon NM-200R2 with about 20 hours on it for sale (motivated seller)but...
    Jun 2010
    4
    I have a NM-200R2.
    I purchased this machine for a design school for about $12000 and it just didn't fit into the curriculum so it wasn't used.
    This machine has only about 20 hours of use in it's life and I have been trying to fix it off an on ever since it just stopped mid-cut one day.
    I consulted with Novakon and they thought it was the BOB board so I replaced that as directed.
    That didn't work so they suggested a new smooth stepper. That didn't work so I shipped the computer, BOB and smooth stepper to novakon and they tested it and said it was fine.
    When I put it back together I accidentally crossed a wire and cooked the smooth stepper so I got a new one but that doesn't seem to be working either.
    Now I need to move it out, fixed or not.
    Make an offer. (I'm open to suggestions on a fix.)
    You will have to pick up in Providence RI. We have a fork truck.
    Here is what is included.
    NM-200R2. Pro Series Bed Mill including 6K Spindle & REX
    Motors with Attached Electrical Cabinet
    Integrated Controller System
    Full Computer Upgrade: Motherboard, CPU, 2GB RAM
    Hard Drive & Windows 7 O/S
    CNC Controller Software
    NM-200 Coolant System with Pumps and necessary
    cables
    NM-200 R2 Stand
    8" Rotary Table with Tailstock and Stepper Motor/Cable
    4th Axis Gecko Driver Upgrade
    (6") Vise, 160mm x 140mm Jaw Opening
    5/8", 58 pc Clamp Set (for NM-200)
    Collet Set, R8 Arbor with ER25 Collet Set (1mm -
    16mm) and Wrench
    Novakon Quick Change Tool
    Collet Holder 3/4"-ER 20
    ER20 Collets 1/8"
    ER20 Collets 1/4"
    ER Collets 3/8"
    Keyless Drill Chuck, 5/8" x JT6
    Hole boring cutting cutter adaptor
    hole boring cutter set (9 PCS)
    Hole Boring Tool Holder
    Jul 2011
    400
    Re: I have a Novakon NM-200R2 with about 20 hours on it for sale (motivated seller)bu
    There is not a whole lot to the electronics on this mill so it should not be to hard to figure out. How dead is it? No power at all? One or more axis won't move? Do you know how to use the diagnostics page in Mach 3? Do you have a limit switch stuck in the tripped state?
    Jun 2010
    4
    I have someone that made me an offer. I'll update this post if he changes his mind.
    Thanks,
    Jun 2010
    4
    Sold
  1. Novakon Torus pro at 12,000 hours
    By gemcarver in forum Novakon
    Last Post: 11-30-2018, 10:48 PM
  2. Roland MDX-40A For Sale only 390 hours
    By abooth1179 in forum For Sale Only
    Last Post: 07-08-2016, 09:34 PM
  3. Tormach 1100 Series 3 very low hours for sale
    By AVRnj in forum Tormach Personal CNC Mill
    Last Post: 11-18-2014, 12:12 AM
  4. Used Novakon NM-145 for sale here
    By overrev in forum Novakon
    Last Post: 12-12-2012, 03:52 AM
