584,874 active members*
4,970 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Safety change pump (operates by it self on a fluke) HELP!
    Aug 2012
    18
    Quick break down of the hardware and software I'm using to help with diagnosing the issues.
    china 5 axis breakout board, cncdrive uc100 motion controller cnc4pc safety change pump, hp laptop with mach 3 everything is setup correctly and works once mach starts it gets the 12.5 single and once out of restart the charge pump is activated but there is a fluke with it...
    The 5 axis breakout board has a USB port it uses to supply some of the board and relay with 5volts, So with the motion card there are two USB cables going to the computer from the BOB.
    If the computers on with or without mach running and you discount the motion USB cable but the usb cable that is supplying the bob with 5 volts is still connected the charge pump becomes activated... Which throws the whole point of the charge pump out the window. I went back and read the Manuel only thing i didn't do is add a earth ground, but i did jumper the grounds to a a earth ground in the case and it didn't change anything, there maybe some cross talk but its hard tell or to rule that out.
    ANY HELP WOULD BE GREAT APPRECIATED!
    Mar 2007
    2083
    Re: Safety change pump (operates by it self on a fluke) HELP!
    looking at your photo the BOB looks like this one
    Attachment 425040
    if the UC100 micro controller a low power device
    the twelve 10K resistors connecting the BOB's +5V supply to the 74HC245 IC inputs could power the UC100
    by back feeding power into the UC100 output pins via the 74HC245 and UC100 IC protection diodes
    in this state you could be getting spurious signals going to the safety change pump
    example of protection diodes inside IC
Name:	IC protection diodes.jpg
    John
  1. Replies: 0
    Last Post: 11-15-2017, 04:19 AM
  2. Fluke 805 Vibration Meter
    By pickled in forum For Sale Only
    Last Post: 05-08-2017, 05:36 PM
  3. G320 motor tuning issue with Fluke 124 scope
    By turbotoys in forum Gecko Drives
    Last Post: 12-16-2013, 11:54 PM
  4. safety conscience, or safety paranoia?
    By Marino MFG in forum Safety Zone
    Last Post: 04-03-2009, 09:34 PM
  5. Fluke Thermal Imager
    By Dermako in forum Community Club House
    Last Post: 01-26-2007, 02:35 AM
