585,974 active members*
4,219 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > BODOR Laser > bodor x1006 39x24 inch bed 150 watt 5200 water cooler
    Oct 2007
    1019
    looking for ideas of what could be wrong , as the laser tube is not firing:
    --all power supplies are running , green led's showing green, laser tube
    power supply fan is running looks ok
    --checked the lid switch which has an led
    --I bypassed the cooler cw 5200 outlet filter thinking it was restricting the flow
    it did not make any difference
    --I cleaned the cooler filters which were clean
    --i changed the usb cable to the computer made no difference
    -- When the usb is connected to the computer the laser moves very slowly and noisy like its in low gear
    --pushed the system reset front power voltage 1 reads 4.89volts
    --laser runs smooth with no computer hooked up via usb
    --computer will not communicate with the laser says it fails, when i try to download or read settings from the laser
    --my controller is RDC6442S-B (EC)
    --diagnostics off the small screen does nothing
    -everything was running fine until the 48v ower supply failed
    machine alarm says machine protected
    I cannot seem to think of any other permissive to stop the tube firing
    any ideas would be welcome, as I seem to be on my own
    Oct 2007
    1019
    Re: bodor x1006 39x24 inch bed 150 watt 5200 water cooler
    turns out it was a bad relay and controller board has a fault...bodor treats people very badly
    they have no respect for customers
    its well built but take your chances when you need help
    Oct 2007
    1019
    Bodor promptly shipped me a new 2020 controller and I installed it today and its working good
    It was a quick turnaround to get it shipped
    appreciate the quick help
  1. bodor laser 150 watt
    By woodman08 in forum BODOR Laser
    Last Post: 07-31-2018, 02:13 AM
  2. BODOR CO2 150Watt/60 Watt
    By chirssinz in forum BODOR Laser
    Last Post: 02-06-2016, 04:29 PM
  3. Replies: 1
    Last Post: 11-03-2014, 03:20 PM
  4. Using T-Slot Gantry as Spindle Water Cooler?
    By Zuni in forum DIY CNC Router Table Machines
    Last Post: 03-26-2011, 12:48 PM
  5. tig torch water cooler
    By daveb56 in forum Welding Brazing Soldering Sealing
    Last Post: 11-16-2007, 03:26 AM
