Originally Posted by
TomKerekes
Hi Dave,
I think the Panasonic and DYN4 Drivers accept 5V Step/Dir signals.
<Given I am reading the Panasonic driver manual correctly, Step/Dir signals are 12/24v with a minimum of 11.4v. The DYN4 Step/Dir signals are 5 volts with special order 12/24v.
Therefore, 5-24V line drivers will be needed for the Panasonic driver, and the DYN4 will Step/Dir with 5 volts.>
Have you considered using the +/-10V Analog interface to those drives? This would make for a more closed loop system with encoder information feeding back to the Controller (KFLOP) and be somewhat more standard and straightforward. This will involve tuning the servos in KFLOP which may or may not be an advantage for you. This would also permit you to use JP4 for Konnect for the additional 24V IO.
