585,568 active members*
3,752 visitors online*
    Aug 2019
    4
    Problem with co2 power supply sound
    Hi, I bought an used K40 laser cutter and the owner saw that the co2 tube has two years and need to be replaced.... I can cut (in 2 or 3 steps) 4 mm acrylic... I can engrave, can cut paper, engrave acrylic.... my question is...
    The power supply has a noise when co2 tube ON but no always... but almost time... sometimes noise, sometimes no noise....
    Here is a demo video of the power supply noise, I opened the power supply and capacitors are not inflated and board looks good.
    https://www.youtube.com/watch?v=PyFmPb_lIM4
    Can the noise be generated by a wasted co2 tube or can be the power supply damaged?
    Thanks in advance!!
    Sep 2005
    1740
    Re: Problem with co2 power supply sound
    Used K40 machine with PS and tube bad? New ones are like $300 on eBay and they are the cheapest POS machines you can buy. Sure you can upgrade, tweek and improve but why? Your more than likely hearing high voltage arcing inside the PS or on the HV cable touching metal and arcing over someplace. Turn off the lights in the room and look for the arc.
    Aug 2019
    4
    Quote Originally Posted by wmgeorge View Post
    Hi, I bought used because it comes with a DM442 servo controller and a RDC6442G controller and some mods... the controller only costs the price that I paid for the machine...
    I can´t see the arc, this sound is sure an arc on the PS, right? Or inside the flyback.... Maybe changing the flyback....
    Thanks!!
    Aug 2019
    4
    At full power, at 99% power, it doesn´t do any noise... and cut right
  1. Is my power supply the problem?
    By Devoreg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-25-2016, 07:53 AM
  2. Power supply problem
    By mondo50m in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-06-2012, 08:25 PM
  3. power supply problem
    By rashdan in forum CNC Machine Related Electronics
    Last Post: 02-28-2012, 08:30 PM
  4. TL-1 power supply problem
    By rideredcr in forum Haas Lathes
    Last Post: 09-03-2008, 07:48 AM
  5. ATX 2 power supply problem
    By flannman in forum CNC Machine Related Electronics
    Last Post: 05-28-2006, 07:19 PM
