585,991 active members*
6,512 visitors online*
Results 1 to 7 of 7
    Dec 2015
    4
    Question Power Supply Size?
    I just got new stepper motors for my DIY router and I'm a little confused how large the power supply has to be. I'm planning on getting a 36V power supply.
    How many amps should i get in case all 4 motors are at full load? I can't find an explanation how to roughly calculate the power draw of stepper motors.
    I have 4 motors (2x on the X axis)
    https://www.omc-stepperonline.com/ne...s45-4204s.html
    And these are the stepper drivers.
    https://www.omc-stepperonline.com/ne...l?search=M542T
    Thanks!
    Jan 2018
    1516
    Re: Power Supply Size?
    Normally if you get these similar type 4 axis kits from China you're given 2 psu's to these specs:
    https://www.ebay.co.uk/itm/1PC-CNC-R...gAAOSwpLxcei4k
    (1 supply per 2 motors/drivers).
    You can run these nema 23 kits on 48v supplies if wanted as well.
    Aug 2005
    1092
    To calculate current requirements for a stepper motor multiply the motors rated current by 2/3.
    So, you’re motor is rated at 4.2A. Multiplying it by 2/3 gives 2.8A per motor.
    If you plan to use 3 motors that’s a total of 8.4A. For 4 motors that’s 11.2A
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
    Aug 2005
    1092
    You could use a single 48v 12A supply such as;
    https://www.homanndesigns.com/index....roducts_id=288
    Cheers
    Peter
    Jan 2018
    1516
    Depends on the budget as well. The Meanwell are nice but for half the cost you can buy 2 of these:
    https://www.ebay.co.uk/itm/AC-110V-2...AM6BF6r8RrwhVg
    Import the Chinese 48v 7.2A 360w version for £21.00 each. Spot on, and I bet they'll put it down on the customs form as a $10 cost!!
    Mar 2007
    2083
    if you use this from Geckodrive.com's web site to select your supply voltage
    see
    https://www.geckodrive.com/support/s...ly-basics.html
    32 * ?L = VMAX
    with your stepper motor with an inductance of 3,8mH
    your looking for a supply voltage of 32 * 1.95 = VMAX = 62V
    to avoid limiting the maximum speed you can step the motor
    that requires a more expensive stepper driver
    if you can find a stepper motor closer to 2.6mH to 2.8mH then a 48V supply will be OK
    John
    Jan 2018
    1516
    Quote Originally Posted by john-100 View Post
    see
    32 * ?L = VMAX
    John
    This is when seeing some of these Chinese sellers flogging 23 sized motors with an inductance of 6.6mH and above leaves me scratching my head!?
  1. Power supply size
    By dhaddox in forum DIY CNC Router Table Machines
    Last Post: 10-07-2011, 02:45 PM
  2. Power supply size ??? for Stepper Motors
    By wdysf150 in forum DIY CNC Router Table Machines
    Last Post: 01-19-2009, 08:23 AM
  3. Newbie : What size of power supply???
    By Bigguns in forum DIY CNC Router Table Machines
    Last Post: 07-02-2008, 05:42 PM
  4. How hard is it to figure out the size of cap and bridge rectifier for a power supply
    By journeyonline in forum CNC Machine Related Electronics
    Last Post: 04-04-2007, 10:31 PM
  5. Power Supply Size
    By Jcadwell in forum CNC Machine Related Electronics
    Last Post: 04-22-2004, 05:01 PM
