585,927 active members*
4,059 visitors online*
    Aug 2019
    Good laser for cutting wood
    Hi All,
    I would like to cut complex patterns in 3-4mm plywood with laser. My goal is to make clean and burn free cuts as fast as possible, probably with one path.
    What kind of laser has the best energy level and wave length for that job? Can non CO2 diode lasers cut wood?
    Can you recommend an exact non industrial size laser cutter for that?
    Thank You
    Sep 2018
    36
    Re: Good laser for cutting wood
    CO2 is definitely the way to go, but a diode won't be powerful enough. You can get away with using a 40-60W laser and get nice clean cuts in one pass. Check out the Aeon MIRA, this is a great desktop CO2 laser and will do everything you need it to. Aeon Laser USA
    Nov 2015
    371
    Quote Originally Posted by Bakta View Post
    3-4mm plywood.. burn free cuts
    I don't think you can achieve this with a laser. A rotary plotter/router would be a better choice.
  1. Cutting MDF Wood with Laser CO2
    By ttnc4plus in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-16-2019, 02:59 AM
  2. Laser wood model cutting – cutting a chair
    By Nolan Yang in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-22-2014, 07:17 AM
  3. Replies: 0
    Last Post: 08-15-2011, 03:08 AM
  4. which laser for wood cutting
    By colormecnc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-14-2007, 07:05 PM
  5. Where can I find Good CNC Wood Cutting machine for Car parts size ?
    By Calico in forum DIY CNC Router Table Machines
    Last Post: 02-28-2005, 06:36 AM
