585,668 active members*
4,312 visitors online*
Results 1 to 6 of 6
    Feb 2014
    5
    MACH 3 OEM Spindle Stop button
    Hey guys,
    So I've been looking through lists of OEM buttons for Mach 3 that I have found in several different places on the internet, as well as lots of Google searches, but I cant find any info about a more specific code I'm trying to find, so it might not exist.
    I'm looking for a code to turn the spindle off no matter which direction it is going. I'd like to have 3 panel mounted buttons, one for CCW, STOP, and CW. I know that if the CW button is pressed twice, it will
    stop the spindle, but I'm looking for a button that will stop the spindle and nothing else.
    Any ideas?
    Re: MACH 3 OEM Spindle Stop button
    Have the button call M5.
    Feb 2014
    5
    Gerry, Thanks for your reply.
    How do I assign a button to a specific M code? I did some searching and came up empty handed
    If it's a button wired to an input, you'd use the macropump macro to monitor the input, and call the M5.
    Feb 2014
    5
    No luck yet. All I manage to get is a syntax error from VB editor from what I've entered into my macropump.m1s file:
    If GetLED(821)=1
    Then
    DoSpinStop()
    I have verified function of input 1 using the diagnostic screen, but cant get it to do anything.
    Feb 2014
    5
    Update:
    With more relentless tinkering and a .pdf guide I found, I came up with
    If IsActive(Input1) Then
    DoSpinStop()
    End If
    This functions as desired for a command that just stops the spindle. Thanks Gerry for getting me pointed in the right direction
  1. How to configure a soft stop button - Not E-stop
    By Jmhx2 in forum UCCNC Control Software
    Last Post: 07-21-2019, 11:48 PM
  2. Spindle start/stop G540 and Mach 3
    By cnc170 in forum Australia, New Zealand Club House
    Last Post: 07-31-2015, 05:13 AM
  3. E stop button
    By 85burban in forum Tree
    Last Post: 02-23-2012, 12:57 PM
  4. Replies: 10
    Last Post: 10-24-2008, 04:11 PM
  5. E-Stop Button
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 05-19-2008, 08:41 PM
