585,975 active members*
4,865 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 750 has no power on the PSR 4/5 250-7500
Results 1 to 9 of 9
    Aug 2019
    Good Morning Everyone,
    So I am having a problem with an Arrow 750 in my facility. The PSR 4/5, the VSF5 spindle drive and all of the axis drives have no power on them. No lights, nothing. They don't come on at all.
    I have 120v coming into the C1 on the PSR and I have taken it apart to check the fuses but they are good. ( I read about some guys doing that on other threads.)
    The machine has a Vickers arrow 2100 output board. One of the other problems is the machine was bought used and does not have any prints with it. None.
    Thank you
    Dec 2006
    584
    Re: Arrow 750 has no power on the PSR 4/5 250-7500
    The 120vac on the PSR is converted to +_ 18 vDC and + 10 VDC from the PSR and goes to each drive for board logic ( daisy chain ). If you don't have any lights on the axis drives you need to look at the DC voltages.
    On the spindle drive plug C4 pin 5 is + 18 vdc, pin 6 is - 18vdc, pin8 is +10vdc and pin 7 is common. Pin 1 and 2 is 120 VAC
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services.
    Dec 2008
    18
    My arrow is having the same issue. Should i send the PSR in for rebuild?
    Sep 2010
    1765
    Quote Originally Posted by nismopu View Post
    Answer is probably yes. Be careful who you send it to repair: many 3rd party folks do not repair our old drives well.
    Dec 2008
    18
    Quote Originally Posted by mike_Kilroy View Post
    Who do you recommend?
    Sep 2010
    1765
    Did you check C4 voltages Mechardt55 gave you? If you have them, then your issue can be something else.
    Dec 2006
    584
    You need to send it to Mike Kilroy and no one else. Mike will fix your problem. Did you check the voltages??? Where are you located?
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2022
    6
    Quote Originally Posted by meckardt55 View Post
    I have the voltage to the pins that daisy chain to the other drivers. But I don't have the main voltage to the unit. The contactor that supplies it pulls in when I press the power on. But then reads error on the spindle driver and throws a error on the control.
    The spindle driver has already been for a repair.
    All the axis drivers are read under volts. But that's obvious if the bus + and - haven't got any volts coming out from the power supply because the contactor won't hold in because there is a fault.
    What voltage should come out from the bus lines on the power supply?
    Mar 2008
    285
    Search the Cincinnati forum for VFS5 and BDS5 posts. There are several handshakes and pieces that need to work to power the bus contactor on with no faults.
    Bill Oehler can work with you on the phone if you have the prints for your machine that match those stamped on the serial plate; Control Diagrams, 9120xxxxyyy.
    His contact info is on the site as well.
  1. Arrow 500 no power up.
    By chopsmitty in forum Cincinnati CNC
    Last Post: 04-04-2017, 08:07 PM
  2. Cincinnati Arrow 1000 won't power on.
    By mvas82 in forum Cincinnati CNC
    Last Post: 04-09-2014, 07:13 PM
  3. Arrow 500 power supply need help
    By leonmathis in forum Cincinnati CNC
    Last Post: 04-07-2014, 04:43 PM
  4. Closing the doors on my Arrow shuts the power off
    By mmckell in forum Cincinnati CNC
    Last Post: 07-22-2011, 04:57 PM
  5. Arrow 500 - Acramatic 2100 No Power to Controller
    By hodge_thomas in forum Cincinnati CNC
    Last Post: 05-10-2010, 01:36 PM
