585,759 active members*
4,005 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Can I cut a bit of the z-lead screw on a Taig mill?
    May 2006
    309
    The Z-lead screw often crashes with my wooden work pieces if they are high enough to reach that level, so I need to know if it is possible to cut a bit of this lead screw and how much I can cut without creating any problems.
    Jun 2011
    68
    Re: Can I cut a bit of the z-lead screw on a Taig mill?
    That is all up you!!!
    The only limitations on how much your remove.....
    How close to the table will you ever cut ???
    Depending on your requirements
    A spacer block for the headstock may help...
    good luck
  1. Tormach PCNC 440 Mill precision/ Rolled lead screw
    By astromachinist in forum Tormach Personal CNC Mill
    Last Post: 03-08-2016, 04:24 PM
  2. Lead Screw pitch and Bearings,coupling for lead screw
    By Power_user_EX in forum Linear and Rotary Motion
    Last Post: 06-12-2012, 12:37 PM
  3. Mini Boring Head for Taig Mill (lead screw graduations)
    By slashr76 in forum Taig Mills / Lathes
    Last Post: 08-29-2010, 08:27 AM
  4. Taig - Wandering mill, Lead screw?
    By bluumax in forum Taig Mills / Lathes
    Last Post: 05-23-2008, 11:14 PM
  5. taig mini-mill screw conversion: acme or ball?
    By nickydubs in forum Taig Mills / Lathes
    Last Post: 10-25-2006, 05:12 PM
