Originally Posted by
salukikev
I've been reminding myself for at least a year now to try and sort out this quirk of my machine and I finally remembered:
So I have an old Tripower bridgemill that 99% of the time I use manually, but it's also wired for CNC which is great when I need it. Still in the process of converting to ballscrews instead of acme thread. A thing I noticed more pronounced recently is that if I rotate my X axis crank fast enough, I feel occasional pulses relaying through the Y axis handle. Usually it's not a huge problem and I can generally eliminate it by slowing down my rotations but I've always thought there was probably just a setting or strategic diode I could put in there somewhere and that this would be a good place to ask. I haven't yet found a post describing exactly this problem- I guess I was expecting it to be a bit more common.
Anyway, thanks for any help!
-kevin
