585,737 active members*
4,704 visitors online*
    Feb 2018
    8
    Jerky movement with Mach3 and Mastercam
    Hello!
    I just finished my 4th axis build on a homemade CNC router. I did some positioning and wrapped toolpath in Fusion 360 and both worked fine. Then, I wanted to test some simultaneous milling with Mastercam and I can't seem to get it to work properly. First, I tried generating G code with Generic Fanuc 4X Mill and also Generic Haas 4X Mill post processors, but the toolpath I get from that is wrong. So next I tried with Generic Fanuc 4X Router post and got the correct toolpath. But when I run it on my machine, the movement is jerky and feedrates get very low sometimes(inconsistent feed). I will attach a link to a video so you can see and hear exactly what is happening.
    I also tried generating G code in inverse time feedrate(G93) but the movement is still jerky/inconsistent.
    Now i need your help, I think I tried changing every setting in Mach3 (CV, Look Ahead, Rotating Diameter,...maybe there is still something I forgot.)
    Maybe there is a problem with Mastercam calculating weird feedrates. I will post a sample of G code generated by Generic Fanuc 4X Router post and a screenshot of the toolpath. The toolpath is Multiaxis > Blade Expert and it is 4 axis roughing.
    https://www.youtube.com/watch?v=0YjfhWgqcZU ! Sound on !
    G code with G94: (on default post processor settings)
    (PROGRAM NAME - MASTERCAM TEST4)
    (6 SPHERICAL / BALL-NOSED ENDMILL TOOL - 1 DIA. - 6.)
    N100T1M6
    N110S2000M3
    N120G0G90X-2.5Y26.929Z38.538A26.202
    N130Y27.221Z34.866
    N140G1Y28.015Z24.898F1200.
    N150X-1.748Y26.896Z24.958F1500.
    N160X-.783Y25.56Z25.005
    N170X-.166Y24.5Z25.016A26.352F183.2
    N180X.147Y23.654A26.769F680.2
    N190X.483Y22.639Z25.013A27.259
    N200X.813Y21.453Z25.005A27.817F667.4
    N210X1.164Y19.757Z24.993A28.592
    N220X1.366Y18.569Z24.984A29.125F651.8
    N230X1.516Y17.209Z24.976A29.721
    N240X1.585Y15.849Z24.972A30.306F634.
    N250X1.596Y14.659Z24.971A30.814
    N260X1.636Y13.294Z24.968A31.196F416.6
    N270X1.612Y12.271Z24.969A31.481
    N280X1.517Y10.905Z24.973A31.859
    N290X1.36Y9.54Z24.981A32.236
    N300X1.081Y7.92Z24.992A32.684F405.9
    N310X.818Y7.717Z25.001A33.291F2000.
    N320X.602Y7.531Z25.007A33.853
    N330X.426Y7.362Z25.009A34.382
    N340X.284Y7.21A34.896
    N350X.168Y7.075Z25.008A35.409
    N360X.071Y6.958Z25.007A35.939
    N370X-.014Y6.857Z25.005A36.499
    N380X-.092Y6.773A37.103
    N390X-.205Y6.716A37.79
    N400X-.295Y6.695Z25.007A38.37
    N410X-.372Y6.709Z25.008A38.866
    N420X-.451Y6.76Z25.01A39.312
    N430X-.554Y6.846Z25.011A39.759
    N440X-.702Y6.968Z25.009A40.254
    N450X-.912Y7.126Z25.004A40.835
    N460X-1.195Y7.32Z24.992A41.528
    N470X-1.139Y8.95F1500.
    N480X-.861Y10.296Z25.003A40.895F677.5
    N490X-.643Y11.643Z25.01A40.26
    N500X-.419Y12.658Z25.015A39.561F967.5
    N510X-.188Y14.012Z25.018A38.624F981.
    N520X-.042Y15.197Z25.019A37.796F995.9
    N530X.07Y16.551A36.84F1008.6
    and G code with G93:
    (PROGRAM NAME - MASTERCAM TEST 21)
    N100T1M6
    N110S2000M3
    N130Y27.221Z34.866
    N140G1Y28.015Z24.898F0.
    N150X-1.748Y26.896Z24.958F1000.
    N170G93X-.166Y24.5Z25.016A26.352F792.5
    N180X.147Y23.654A26.769F1020.6
    N190X.483Y22.639Z25.013A27.259F866.
    N200X.813Y21.453Z25.005A27.817F759.3
    N210X1.164Y19.757Z24.993A28.592F546.1
    N220X1.366Y18.569Z24.984A29.125F790.4
    N230X1.516Y17.209Z24.976A29.721F704.3
    N240X1.585Y15.849Z24.972A30.306F715.1
    N250X1.596Y14.659Z24.971A30.814F824.4
    N260X1.636Y13.294Z24.968A31.196F724.6
    N270X1.612Y12.271Z24.969A31.481F972.2
    N280X1.517Y10.905Z24.973A31.859F731.6
    N290X1.36Y9.54Z24.981A32.236F732.6
    N300X1.081Y7.92Z24.992A32.684F616.4
    N310X.818Y7.717Z25.001A33.291F4923.5
    N320X.602Y7.531Z25.007A33.853F5310.6
    N330X.426Y7.362Z25.009A34.382F5621.2
    N340X.284Y7.21A34.896F5793.6
    N350X.168Y7.075Z25.008A35.409F5786.7
    N360X.071Y6.958Z25.007A35.939F5604.6
    N370X-.014Y6.857Z25.005A36.499F5294.1
    N380X-.092Y6.773A37.103F4916.6
    N390X-.205Y6.716A37.79F5125.3
    N400X-.295Y6.695Z25.007A38.37F6074.9
    N410X-.372Y6.709Z25.008A38.866F7119.
    Any help would be appreciated. I also attached a screenshot where I can set the output format for feedrate, maybe I have something wrong here. If I forgot to mention something I will reply as quick as possible.
    Jul 2011
    400
    Re: Jerky movement with Mach3 and Mastercam
    Do you have "exact stop" turned on in mach 3? Exact stop can cause pauses in movement.
    Aug 2019
    339
    Hard to say, can you post the init header of your program?
    Are you calling G64 from code with a few lookahead lines set-up (100 to 200 lines?)
  1. Stop/Start, Jerky, Shutter Movement with Mach3
    By mikefalkner in forum Mach Mill
    Last Post: 04-23-2019, 03:22 PM
  2. jerky g0 movement
    By Lozzy in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-31-2018, 12:51 AM
  3. Chatter movement/Jerky movement
    By adescoteaux in forum Mach Software (ArtSoft software)
    Last Post: 10-21-2016, 01:41 PM
  4. KFLOP + Mach3 Config Problems - Jerky Movement Trips Servo Drives
    By goldenfab in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-02-2016, 09:36 PM
  5. Jerky Movement
    By elogicca in forum Mach Mill
    Last Post: 11-22-2007, 03:19 AM
