585,758 active members*
4,218 visitors online*
    Aug 2019
    Mach3 Slave with Sainsmart STB5100
    So recently purchased the Sainsmart STB5100
    Trying to setup the Y axis to slave with A axis
    So far no luck
    Watched all the youtube videos of correct settings etc but still didnt work
    Steppers will only operate individually
    Tried Using DrufelCNC which had support for the USB Breakout but then was having issues where the steppers wouldn't move at all, but rather just cog the lack of support in community and google searches made me give up on that
    at this stage if i cannot find a solution for this board, think ill just get another breakout as its really frustrating wasting 2 days with such a simple issue that should have worked
    If anyone has a solution of can help would greatly appreciate it.
    Cheers
    Re: Mach3 Slave with Sainsmart STB5100
    Hi I have been having the same issue. I followed the software setup in mach3 to enable the A axis in pins & ports, set it as slave to Y in slave axis settings and even reversed the operation under homing/limits. Option1: There is 1 more software setting that I think needs to happen though I have not been able to access any settings under "Plugin Control" --> BL-UsbMach if you click on "BL-UsbMach" I believe this should bring up settings for the STB5100 then on this screen you can make some change to set A axis to slave with Y. Nothing happens when I click BL-UsbMach so I am thinking I have an old version of Mach3 or something. Let us know if you have any success. Option2: Don't use Mach3 to slave anything just enable your XYZ axis as usual then wire the A-axis driver in parallel to the Y-axis driver. If you want the same rotation for both A & Y then you are done. If you need A to turn in the opposite direction from Y then you need to invert the DIR signal coming from the STB5100. Use a 5V hex inverter 74HC04. This will be my solution though I am a bit confused why I cannot get mach3 software to actually drive Y & A at the same time.
  1. Mach3 ref all home with slave axis
    By HuguesP in forum Mach Software (ArtSoft software)
    Last Post: 12-01-2020, 08:25 PM
  2. Issue with A-axis on Chinese Workbee Stb5100
    By Workbee1x1 in forum Machines running Mach Software
    Last Post: 05-22-2019, 04:46 AM
  3. Sainsmart 4 axis mach3 USB breakout board plugin
    By Ctimbs in forum CNC Machine Related Electronics
    Last Post: 12-26-2016, 08:00 PM
  4. Mach3 Slave Axis problem
    By Darian S in forum DIY CNC Router Table Machines
    Last Post: 07-31-2014, 04:06 PM
  5. G540 + Mach3 Slave Y & X axis
    By dglasco in forum Gecko Drives
    Last Post: 09-28-2013, 10:23 PM
