584,805 active members*
5,331 visitors online*
    Dec 2018
    UCNC Motion planning question
    Question for anyone in the know as I haven't been able to find the answer around.
    For background: I am looking at buying a UC100 to mate with my g540 on a custom gantry style mill I have made and running it via UCNC. Currently I am running Grbl but have run into it's pulse per second limit (~30,000). In trying to find an upgrade I came across G2Core which has a much higher pulse per second rate and a jerk controlled motion planner (more info here: https://github.com/synthetos/g2/wiki...tion-Explained). I haven't had much luck getting it to work relaibly but found the few times it was working that the acceleration profiles were much gentler and produced much less noise but were overall faster than the trapezoidal style motion profile of Grbl.
    Does UCNC use the standard "trapezoidal" acceleration profiles or does it have some jerk limiting to smooth out the motion of the machine?
    Jun 2015
    943
    Re: UCNC Motion planning question
    It has trapezoidal profile, just like how Mach3, Mach4, Linuxcnc, Acorn all have trapezoidal profiles. If you looking for S curve profile you might want to take a look at EdingCNC.
    CNC Drive is planning on an S Curve Planner for UCCNC, but I wouldn't expect it for at least a year or more.
  1. Motion Control Question
    By JoeKumanchik in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-15-2016, 02:45 PM
  2. Motion Controller Question for G0704
    By helfires688 in forum Benchtop Machines
    Last Post: 08-08-2014, 01:51 AM
  3. Motion Clamp Question
    By Dave3891 in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-16-2013, 05:11 PM
  4. Build thread - UCNC: First Step - Electronics
    By kuolas in forum Open Source Controller Boards
    Last Post: 10-16-2010, 04:05 PM
  5. Galil motion controller question
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 07-22-2007, 10:24 PM
