585,974 active members*
4,188 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan puma mx2100 rigid tapping alarm
    Oct 2008
    23
    Hello!
    I need help with the issue by rigid tapping with lower turret on left spindle.
    I get alarm for RIGID MODE DI SIGNAL OFF.
    I don't know where is the problemm in programm.If I enter M29 S300 P21 or P22 cycle work normaly.Only with the P11 doesn't want to work.
    Can anybody help me.
    Regards
    Janko
    Jul 2005
    380
    Re: Doosan puma mx2100 rigid tapping alarm
    There are a few things here.
    You're trying to access the main spindle from the lower path. If you "really" want to do that, you need an M264 "other pulse coder" command on a line by itself BEFORE the commands and then a M265 afterwards.
    Oct 2008
    23
    Quote Originally Posted by DouglasR View Post
    That's right!
    I tryed with M264 but I get the same alarm.
    Jul 2005
    380
    Hmm..
    M264 Has to be on a line by itself, before any spindle commands.
    the rigid tap line should read G97S250M29P11 then the G84 Z-.5F.05, G80, then M265.
    Oct 2008
    23
    Hmm..
    I tryed but I get the same Alarm on
    Line
    G97S250M29P11
  1. DS0300 APC Alarm on DOOSAN PUMA 2600LSY
    By DanielBamek in forum Fanuc
    Last Post: 03-29-2022, 07:08 AM
  2. Fanuc 18-M alarm when rigid tapping
    By pufferfish in forum Fanuc
    Last Post: 05-23-2016, 06:37 PM
  3. Doosan MX2100 ST 2012 Machine 500k$ New Now 350K$
    By ifixcnc in forum For Sale Only
    Last Post: 04-25-2014, 03:50 PM
  4. ALARM 2034 - MOTOR OVERLOAD - DOOSAN PUMA 400L
    By rpm3000 in forum Daewoo/Doosan
    Last Post: 01-21-2014, 11:43 PM
  5. APC Alarm - Doosan Puma TL2000
    By bullet01 in forum Turning Machines
    Last Post: 12-15-2011, 03:05 PM
