585,685 active members*
4,844 visitors online*
    Jan 2018
    1516
    UCCNC400ETH & Mach3?
    Noob question.
    Anyone using this combination of UCCNC400 & Mach3?
    I've seen a plugin for it but is the setup stable?
    Should I just go with the ESS Smoothstepper and not look at anything else when the time comes?
    Re: UCCNC400ETH & Mach3?
    It should be just as stable as the ESS.
    I'd recommend the AXBB-E. It has more features, and you don't need a breakout board.
    I'd also pay the $60 and switch to UCCNC, which is far superior to Mach3.
    Jun 2015
    943
    Quote Originally Posted by dazp1976 View Post
    Noob question.
    I used that combination for some time and it worked fine, but then moved to UCCNC.
    Aug 2015
    142
    Uccnc is better than mach 3 .
    I wolud not use mach 3 after i use uccnc .
  1. Mach3, 2010 Screenset, Mach3, G540, UC100, Win 10 - Will not home
    By SteveS in forum Mach Software (ArtSoft software)
    Last Post: 04-25-2019, 05:49 PM
  2. To mach3 or not mach3, opinions requested
    By KenCameron in forum HURCO
    Last Post: 10-07-2014, 10:05 PM
  3. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
