585,959 active members*
5,182 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > NM-135 gibs adjustments
Results 1 to 8 of 8
    Hey guys. I need to adjust the gibs on my NM135 and since I can’t find a manual with picture I do not know which screws is the tapered one and which one is the lock.
    Anyone can point me in the right direction?
    Aug 2007
    359
    Re: NM-135 gibs adjustments
    Don't have to be too bright to be me
    Hey MKlotz70, I turned on PM option.
    I cannot see the link you posted, says video unavailable.
    I have tapered gibs on that machine if that helps.
    Jan 2016
    386
    This is from the Pulsar manual. Hopefully it will help some.
    Jan 2016
    386
    A quick search found the 135 manual like you said without pictures.
    http://s172429501.onlinehome.us/NM-135%20manual.pdf
    - - - Updated - - -
    Aug 2007
    359
    The Torus has straight gibs, so it wouldn't be of any help. NYCCNC on youtube has done tapered gib adjustments on his Tormachs before. Video is typically better than pictures.
    Steve303, the Pulsar is different it uses straight gibs with many set screws.
    Thanks for the replies. I came home this afternoon and took the gibs apart. On the X axis the right side is the adjustment and the left a stop/lock.
    On the Y it is front is adjustment and on the Z it is the top one.
    The adjustment screw is recessed in the gibs and the lock sits on top (over the end).
    Hope that makes sense!!!!
    GST
  1. Old servos and adjustments?
    By sortafast in forum Servo Motors / Drives
    Last Post: 03-18-2016, 04:36 PM
  2. RE Crossfeed Adjustments
    By SPEEDRE in forum Mini Lathe
    Last Post: 03-15-2013, 08:47 PM
  3. Crossfeed Adjustments
    Last Post: 02-11-2013, 06:49 PM
  4. Parameter adjustments T3
    By g00g00 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-04-2011, 08:47 AM
  5. Taper gibs vs Parallel gibs
    By Oldmanandhistoy in forum Linear and Rotary Motion
    Last Post: 09-09-2007, 01:25 AM
