584,850 active members*
4,394 visitors online*
    Jan 2011
    13
    Water cooled spindle
    Hello
    I just finished an aluminium extrusion CNC mill project, which I'm currently using with a router Boch colt 1.0 hp.
    Now, I want to limit the noise first, and increase the power of the engine a little with a water colled spindle.
    I'm in a dilemma, I use a standard 110v household with mostly 15 amp breakers. Obviously, I'm looking for a relatively powerful engine that could go up to 0.5" shank. I'm not so knowledgeable in electricity, but I think I could be limited by the type of power I use.
    I would like to know your opinion and suggestions on the subject.
    I'm considering the following two products:
    1) VFD CNC spindle 110v 2.2 Kw er20 collet (1st choice)
    2) VFD CNC spindle 110v 1.5 Kw er11 collet (2nd choice)
    Thank you !
    Jack
    Aug 2019
    31
    Hi jack,
    I suggest you equip a 110VAC to 220VAC transformer. Because most of the spindles are 220VAC or 380VAC types when their power are over 1KW.
    Re: Water cooled spindle
    this one may meet your need
    110V WATER COOLED SPINDLE MOTOR ER20 2.2KW SPINDLE + 2.2KW DRIVE INVERTER VFD
    https://www.automationtechnologiesin...2kwvfdspindle/
    Jan 2018
    1516
    Quote Originally Posted by JackMath View Post
    Hello
    Thank you !
    Jack
    Hi matey.
    Well in terms of sizes:
    ER11 collets go up to 7mm diameter.
    ER20 collets go up to 13mm diameter.
    You said you want to use 0.5" shank tooling (1/2" I assume your meaning) which is 12.7mm diameter.
    Pretty much answers the question, the ER20.
  1. Spindle ER11 water cooled VS. ER16 air cooled
    By joaopcrodrigues in forum DIY CNC Router Table Machines
    Last Post: 11-06-2018, 05:47 PM
  2. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  3. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
  4. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  5. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
