585,728 active members*
4,508 visitors online*
    Jan 2011
    14
    Water cooled spindle
    Hello
    I just finished an aluminium extrusion CNC mill project, which I'm currently using with a router Boch colt 1.0 hp.
    Now, I want to limit the noise first, and increase the power of the engine a little with a water cooled spindle.
    I'm in a dilemma, I use a standard 110v household with mostly 15 amp breakers. Obviously, I'm looking for a relatively powerful engine that could go up to 1/2" shank (if possible with my 110v setup). I'm not so knowledgeable in electricity, but I think I could be limited by the type of power I use.
    I would like to know your opinion and suggestions on the subject.
    I'm considering the following two products:
    1) VFD CNC spindle 110v 2.2 Kw er20 collet (1st choice)
    2) VFD CNC spindle 110v 1.5 Kw er11 collet (2nd choice)
    Thank you !
    Jack
    Jan 2018
    1516
    Re: Water cooled spindle
    Hi matey.
    Well in terms of sizes:
    ER11 collets go up to 7mm diameter.
    ER20 collets go up to 13mm diameter.
    You said you want to use 0.5" shank tooling (1/2" I assume your meaning) which is 12.7mm diameter.
    Pretty much answers the question, the ER20.
  1. Spindle ER11 water cooled VS. ER16 air cooled
    By joaopcrodrigues in forum DIY CNC Router Table Machines
    Last Post: 11-06-2018, 05:47 PM
  2. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  3. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
  4. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  5. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
