585,922 active members*
3,803 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Used S3 1100 ATC Install Problem-
    Feb 2008
    92
    I bought a used S3 ATC to install on my S3 1100.
    I wired it up wrong at first since I didnt realize that i didnt have all the cables. I wired the ATC control box RJ11 cable to the VFD. I corrected all of this. Wired the Rj11 cable from PDB to VFD (T1/B3). Took a RJ11 cable I had and connected the PDB to the ATC control board. Also wired the power for the PDB and ATC to the DC bus board. Everything looks correct now on the wiring.
    I am getting a ATC-Spindle Auto Error. The ATC will home but that is it.See attached for my Status screen with the error. Spindle is in Auto mode. PDB will not work either.
    I am wondering if my RJ11 cable I had wont work? Did I fry the ATC control board? Other?
    Was going to call Tormach but not sure they will help since its a used ATC....
    Apr 2011
    720
    Re: Used S3 1100 ATC Install Problem-
    I can't help with your problem because I don't have an ATC, but I believe you should contact Tormach, I would be very surprised it they didn't try to help you.
    Good Luck
    Terry
    Feb 2008
    92
    Thanks, I just gave them a call and filled out a ticket for a call back.
  1. Problem after install
    By RMiroC in forum Screen Layouts, Post Processors & Misc
    Last Post: 04-29-2016, 12:51 AM
  2. UCCNC won't install. Any one have this problem?
    By rlrhett in forum UCCNC Control Software
    Last Post: 11-06-2015, 03:12 PM
  3. Mill v1.27 problem install
    By MILLMANM in forum Centroid CNC Control Products
    Last Post: 01-10-2006, 12:29 AM
  4. Install Problem
    By crow in forum Uncategorised CAM Discussion
    Last Post: 02-18-2005, 05:43 PM
