584,862 active members*
5,812 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Centurion 6 boot up shell
    Feb 2006
    123
    How do i get to the shell in dos with 6 control, on the 5 it says hit F1 and on the older control it's Ctr alt delete, F1 doesn't work and i don't wan't to try the ctr alt delete in case it buggers it up, want to see the path and try and get the ballscrew pitch comp working.
    Sep 2010
    529
    Re: Centurion 6 boot up shell
    I know on the Centurion 5 you do Main-Parms-Setup, then enter Proto3 and then 3, and from there I can't remember, but somewhere it will pop up with exit to DOS. I was just up at my son's last weekend and we did it a lot of times.
    p.s. I'll ask Chris tonight when he's off work, he was the one doing it I was just watching.
    Jun 2010
    132
    This from C6 programing manual page 158
    Get to proteacted mode then
    F9 (Shell) Main-Run-Displ-Shell
    F9 (Shell) is available if the control is in access level 2 or greater. It will Shell out to DOS. To return to the CNC, type exit. F9 (Shell) comes up in protected modes only.
  1. Centurion V won't boot up
    By DEAN-O in forum Milltronics
    Last Post: 08-14-2020, 02:08 AM
  2. CNC egg shell carving
    By uvvvvw in forum Machine Created Art
    Last Post: 08-15-2019, 06:33 AM
  3. Replies: 3
    Last Post: 11-30-2016, 07:23 PM
  4. TM 2 Shell Milll
    By behindpropeller in forum Haas Mills
    Last Post: 02-14-2009, 08:45 PM
  5. Centurion 5 vs. Centurion 6 and validation codes
    By Turbo VW in forum Milltronics
    Last Post: 02-11-2007, 09:35 PM
