585,712 active members*
4,106 visitors online*
    May 2009
    27
    Exclamation VMC 760 HOMING ISSUE
    Bridgeport VMC760 will not home in z axis. It goes up passes the limit and then stops. The maintenance page shows that the limit switch is working properly. The parameters are set correctly. Cannot for the life of me figure out why this thing won't go home. Help!!!!
    Aug 2019
    339
    Re: VMC 760 HOMING ISSUE
    Assuming a mechanical switch; use a DMM to test if that limit switch is operational and signal when triggered. If not (I suspect), replace the switch (suggest replacing all of them).
  1. Homing Issue
    By kreativjustin in forum Fadal
    Last Post: 08-11-2018, 01:27 PM
  2. MH-400 ATC Homing issue
    By mikenboys in forum Maintenance DIY Discussion
    Last Post: 06-04-2014, 04:45 PM
  3. Mach 3 homing issue.
    By evo4wrx in forum CNC Machine Related Electronics
    Last Post: 07-10-2010, 03:04 PM
  4. Homing Issue
    By Moondog in forum Machines running Mach Software
    Last Post: 07-30-2006, 04:23 AM
