585,567 active members*
3,446 visitors online*
Thread: wiring help
    Dec 2017
    26
    wiring help
    what are the normal wires to use to hook the stepper driver to the breakout board i am using 16ga wire for my 120 volt hook up but since the voltage has drop with the connection between stepper and board can i use a 22ga wire
    24220
    Re: wiring help
    22 AWG wire is rated for 3amps, If referring to the control signal to the stepper drive itself, that should be a lot less than 3amps.
    Al.
    Albert E.
    Aug 2019
    339
    Re: wiring help
    24220
    Re: wiring help
    Albert E.
  1. Replies: 19
    Last Post: 07-30-2015, 01:44 AM
  2. wiring check please. parallel wiring to maximum current to servo motors
    By Novett in forum CNC Machine Related Electronics
    Last Post: 10-11-2014, 07:54 PM
  3. need help wiring
    By jim K in forum Stepper Motors / Drives
    Last Post: 01-11-2014, 08:13 PM
  4. Another sPID, G540, and Mach wiring question for the wiring challenged..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-02-2014, 01:29 AM
  5. Wiring help
    By watsonstudios in forum Automation Technology Products
    Last Post: 06-13-2007, 05:32 AM
