585,987 active members*
4,623 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Solidworks Camworks tool length in program
    Aug 2019
    Hi all, I've just joined up as I've started using a Denford 2600 pro router here at work to create prototypes. Were already using Solidworks, but I'm pretty new to the camworks side of things.
    I've set up the technology database and set up a tool crib with various length tools.
    So I set up a test program with a tool change from a short tool to a long tool and ran this on the machine just cutting air to see if the Z position would change to account for the change in tool length. It didn't, the Z height remained the same for both tools which obviously would have been a big problem if cutting actual material / too close to the bed.
    So in the tool crib I've tried adding different values to the boxes "Length Offset" and also tried "Gage Z offset" but neither have made any difference when actually running the program (so I don't know what these values are actually for), the Z height stays the same between tools. So, does anyone know what I actually need to change to make this work? Is it even something that can be controlled by the G code alone?
    Thanks in advance.
    Oct 2008
    4
    Re: Solidworks Camworks tool length in program
    I don't have any experience with the Denford Router, but on milling machines this is usually handled with a tool length offset in the machine control, not in the CAM software.
  1. Applying tool length compensation from C program
    By mmurray70 in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-09-2019, 04:40 AM
  2. Replies: 3
    Last Post: 10-05-2017, 02:03 PM
  3. CAD/CAM SLAM!: CAM for SolidWorks - CAMWorks for SolidWorks
    By cad_cam_slam in forum News Announcements
    Last Post: 06-15-2011, 03:42 AM
  4. Camworks and Solidworks
    By rrbmachining in forum CamWorks
    Last Post: 11-04-2009, 04:31 AM
  5. Camworks in Solidworks
    By CRPDGAZ in forum Solidworks
    Last Post: 11-10-2003, 08:53 AM
