585,951 active members*
3,768 visitors online*
Results 1 to 11 of 11
    Aug 2019
    26
    laser engraving problems
    Can anyone email me the parameters to the china laser engraving machine roudia
    thanks
    Aug 2019
    31
    Which brand or model do you want?
    Jan 2008
    940
    Re: laser engraving problems
    try this one
    Aug 2019
    26
    Thanks, I will try that tonight
    Aug 2019
    26
    I tried to download it to my computer, but I don't know what program to save it as. It is trying to save as a rdworks file? instead of just unzipping onto a saved file?
    Aug 2019
    26
    I did figure how to get the para onto the laser, but now when I print, It wants to print huge, no matter how small I make the it..Could you help me on that,,,you have helped so much, thank you.... I still can't get the laser to go to home base, but at least it is moving up and down smoothly..thanks
    Jan 2008
    940
    First off cut a square that is say 100mm X100mm that you can measure. Then go into your vendor settings and read the file then save it so you can always go back to it. Change the step length for each axis by one half now if you are using my parm it will be .3500 so change it to .1750 and then write that to your controller then cut the same square. measure it and see what the difference is you can the adjust from there either up or down. Hope this helps
    Aug 2019
    26
    Thanks so much, I am going to try it as soon as I get off work, thanks for all your help
    Aug 2019
    26
    I did it and not It prints huge, I am going to download some pics..thanks
    Jan 2008
    940
    My best advise is to see if your vendor will send you the file for your laser. If that doesn't work Still try cutting a 100 x 100 mm square and see how close it is. If it is still to big divide your step number in half and cut again you should get pretty close then just keep adjusting until you get the square to cut 100 x 100 I will have to see if my old laser has the file you need.
    Aug 2019
    26
    When I change my x axis any where close to .3500 the axis barely moves, I always have to change it to at lease 10.0000, do you know why is that
  1. RE: Laser engraving problems
    By ninainwa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-22-2019, 04:49 PM
  2. laser engraving problems
    Last Post: 08-21-2019, 10:48 PM
  3. Having problems with engraving - May need a new laser
    By sports310 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-29-2016, 03:48 AM
  4. laser engraving problems shenhui 350
    By laserdesignlady in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-22-2015, 11:29 AM
  5. engraving / laser machine problems
    By noeleen in forum Community Club House
    Last Post: 05-25-2013, 08:13 AM
