The dirvers that came with my X61500GT CNC Router work quitte well. The only thing I don't like are the JST conectors they use for the wiring.
I'm thinking I may fit some screw connectors like the better quality drivers use.
This came about from noticing the small black connectors on the motrs are getting quite warm, during use.
This means that there are I²R losses and the connector and not something I want.
After there are replaced, the driver connectors are the next weak link.Should be relatively easy.
I've checked the pitches of the connectors ( as best I can ) and they are different and appear to be 3.81mm and 2.5 or 2.54mm.( hard to be sure at this stage.)
I'm looking at options now.
Has anyone done the same mod?
Seems a cheaper and easier upgrade as opposed to buying new drivers when these work fine.
Steve
