585,962 active members*
3,939 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > FineLine Automation > Thanks for the Thread!! Made my decision on which company. NOT FLA...
Page 1 of 3 123
Results 1 to 20 of 60
    Thanks to CNCZONE and it's members for this thread!!! I was just about to pull the trigger on a FLA Saturn2 4x4. However, after reading about the poor customer service and what sounds like poor overall quality. I will be going with AVID CNC, making my order now for the PRO.
    Build:
    4x4 Avid Pro,
    Centroid Acorn or Oak, (haven't decided)
    Clearpath servos,
    GMT spindle...
    Sep 2005
    1740
    Re: Thanks for the Thread!! Made my decision on which company. NOT FLA...
    Quote Originally Posted by BAMBOOROLLINGTIP View Post
    Build:
    4x4 Avid Pro,
    Clearpath servos,
    GMT spindle...
    So your basing your decision on a couple of bad reviews, maybe 4 or 5 total? The one reviewer sent his back for a full refund, and if you ask he will tell you all the issues he had. I have had mine for over a year and no problems. The Saturn 2 is a welded steel frame machine as opposed to one built from aluminum bolted together which will never be as solid as steel,
    Yet others who have never posted here may be happy with their FLA machines, who knows?
    Nothing wrong with Avid / CNCRP at all, just wanted you to know all is not doom and gloom.
    Apr 2003
    540
    Sad to see folks say/do this kind thing regarding Fineline. I bought my Saturn over 2 years ago and the machine has been great and I'll admit the support when I needed it was sometimes slow at times but in the end they always came through and were above and beyond meeting my needs. I'm still very happy with my Saturn and have no regrets whatsoever. I still feel it's the very best machine I could have bought for the money spent.
    Sep 2005
    1740
    Quote Originally Posted by coherent View Post
    Yes there was one very vocal owner who got more than likely the worst FLA machine ever made.... he got his money back and now is in the very long process of building his own machine from extrusions.
    The other two or three folks had complaints for sure, one got an gantry replaced and the other I am not sure of? I really do not have any idea of how many FLA owners there are that are happy users.
    Most of the times people come here to post a build Thread or a complaint, never to say they are happy. Thats just the nature of Forums.
    Nov 2014
    724
    We've had no real issues with our Saturn 2x4 and any small issues we've had Nate has corrected with either upgraded parts or a fix for existing parts. He's a bit slow to respond but I knew that going in. I can't recall when he didn't respond to a question via e-mail or text, even if it was days later. If we had the room I would sell our 2x4 and get the Saturn II 4x4, largely because I like heavy tools and I like the design.
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Aug 2005
    205
    I'm not here to extol the virtues of one make over another, but I would caution you about using anything other then the standard components for the Pro system. As others here have said, if you're making your machine to make parts, making your own control will add a ton of hours to your build. Thats because Avid does not support the use of anything other than steppers with their machine. Don't get me wrong; Avid is great when it comes to customer support. Its just that their control won't run a Clearpath servo. I'm in the middle of building my own control for Clearpath servos for a 2 x 4 Pro machine and its been a bit of a learning curve. Not what I expected.
    Marv
    If you didn't own a Saturn, would you still buy one after seeing the bad machines people got? From a company that doesn't return phone calls or emails? (And has had a reputation for poor support for 10 years). Most people thought he might have gone out of business.
    You're blaming the customers that got ripped off. Fineline is to blame, not the customers. He could have, and should have, taken care of these customers.
    You better check to see if the Oak can even control Clearpaths. I thought it was an analog control, but I could be wrong.
    Sep 2005
    1740
    Yes I would purchase again I had no complaints. The issues from the four or five users that were posted here are the only ones we have seen. Do you know for a fact there are not hundreds of others who are satisfied customers? Could his service be improved, absolutely without question.
    Apr 2010
    109
    To the O.P. you are making the right choice in staying away. I don't have any experience with Avid but they have a long track record. Nate used to be sort of partners with Arron from Avid/Cncrp way back when. Arron dumped Nate because he was horrible with customer service and didn't want his parts associated with that kind of customer care. I for whatever reason always thought Nate was just a little socially retarded, but in the end the truth is he is just a bad guy. I basically took my entire machine apart to try and get it right. It was put together with such a lack of skill or care it was astonishing the machine ran at all. To me it was put together in a way that said," I know better but I don't give a **** ". I told Nate from day one something was off. He sent me a few part and I would go back to the drawing board trying to get it fixed. When I got fed up a year later and told him I was done trying to fix it...he went dark and hasn't answered any of my emails, text or phone calls. The last thing he told me that as it had been too long since I purchased the machine to get a refund...even though he had known I'd been working on it since day one to get the bugs out. The majority of his customers are UNHAPPY...and wouldn't do it over again. Nate and his machines are pieces of ****.
    Apr 2016
    841
    As much as I resolved to stay out of this discussion, it has pulled me in. Bill, you were right. I guess it was inevitable that I'd jump in at some point.
    First, let's break it all down. Apparently, some of the Saturns were built properly. Others seem to have been put together by someone who either didn't know much about welding, or just couldn't care less about workmanship. Either way, some of the machines were junk off the line in the Chinese factory. That's not Nate's fault. He's not the builder. He's the assembler, the final QC guy, and the seller. Therein lies the heart of the problem, IMO.
    Nate does not receive the machines fully assembled. How do I know? Because he had to delay shipping some orders waiting for linear rails to clear customs. I have the emails to prove it. He receives the frames and gantry, adds the linear rails and other parts, installs the gantry on the machine and ships to the customer. I also know, because he says so on his website. Here's the quote: "Designed and Assembled in the United States." (Emphasis added). What is the significance? Glad you asked.
    Because Nate assembles the machines, and some defects are going to be open and obvious to anyone with no more than a passing knowledge of CNCs. Nate knows enough to have recorded an assembly video of his 4 x 4 kit. Take the 4' x 4' I bought and sent back. The first thing I noticed after removing the OxBox were washers placed between the gantry mounting and linear rail interface plate on the left side. (See photos on page 1 of my build thread). That was clear evidence that something was very wrong. I tried to move the gantry. I had to expend too much effort to get the gantry to move at all. Why is this significant? It's significant because Nate was the one who saw that the parts did not fit properly, and was the one who installed the washers. Without the washers, tightening the gantry mounting bolts would have locked the gantry up completely. I knew it instantly. Nate had to know it too.
    I won't bother going over all of the defects. The number is not the point, although there were several.** The point is Nate knew about the defects, knew that there was nothing about the machine that matched up with his published specs, and yet, he sent the machine out to the customer (FWIW, I was a repeat customer) knowing it was junk. I leave it to the reader to apply an appropriate label to what Nate has repeatedly done. I have strong feelings about this sort of behavior. I'm sure I'm not alone.
    In all fairness, I have to say that Nate took the machine back and gave me a full refund. One might say he did the right thing. One might also say it was a reasonable response to doing the wrong thing. I didn't get away free and clear, though. I was still out the cost of building a gantry crane, building two support platforms for my trailer to hold the CNC, and making two harrowing trips to the FedEx depot through horrendous traffic with a top-heavy trailer.
    Others have spoken to the long history on customer service. No need to keep beating that drum.
    Bill,
    (1) There are more than 4 or 5 bad reviews. (2) To focus on the lack of quality in only a few machines totally misses the point, IMO. If it was only one machine, the central problem would nevertheless remain. We have an owner who knew, or darned well should have known that machines were defective and sent them out anyway. There are words to describe the behavior. You know them, just as I do.
    To refresh everyone's memory, Nate says in his advertising, "Our machines come fully assembled, tested, and cut tested." (Emphasis added). If the advertising is truthful, how could Nate send such defective machines out the door? Of course, to believe the advertising, we also have to believe that Nate mounts steppers on X, Y & Z and installs a spindle or router - all necessary to cut testing - and doing it all without lubricating anything, or leaving other evidence behind. Believable? You decide.
    ** If you want more detail, here's a link to my build thread: https://www.cnczone.com/forums/finel...cnc-posts.html
    Erik, FWIW, when I didn't hear from Nate, I sent emails every other day until I did. If it had dragged on very long, I would have increased to daily, 2x/day, or even hourly, if need be. I'm not a patient man when it comes to what I perceive as bad manners/bad business practices.
    Sep 2005
    1195
    Nate made several machines by himself, compare to avid or chinese machines. So his machines lack of quality control. I made 1 ea cnc router machine take about 1 month with alot of attempt to fit bolts, nuts and holes. So do not imagine have a lot expectation from Nate.
    Sep 2005
    1740
    So Gary, what is an accurate count of the posters on the Zone who have had issues? I was guessing at 5 or 6 but you got a full refund, and others have had parts replaced. Someone with some spare time needs to post the count, and there has been several of us posting good feedback perhaps as many??
    So as far as am concerned if you got a refund then that was more than fair. Any of us can cite poor customer service with any company, I am still PO about a couple right now!
    Does Nate need to improve, yes without question but If I had received a full refund I would consider the matter closed.
    Apr 2016
    841
    Quote Originally Posted by wmgeorge View Post
    "More than fair" that I received a full refund????? You really wrote that???? What is fair, then? I should have received 50% for a machine that was seriously defective? I should have eaten the freight cost to return the machine? If getting what was guaranteed was "more than fair," I'd really like to know what you believe would be plain old "fair."
    Here is a copy & paste of Fineline's guarantee.
    "When it comes to our products, we don't mess around. We want you to be satisfied with your purchase, and if you are not, we'll make it right. We guarantee that we'll hold up our end of the bargain. It's just how we do business. If your purchase isn't completely satisfactory, we're happy to give you 100% money back for items purchased directly from us or our distributor network."
    You seem to be missing the main point. It isn't just about machines having defects, getting refunds, repair parts, customer service, or whatever. It's more about what I perceive to be a company knowingly sending defective machines to its customers. Sure, minor stuff can be inadvertently overlooked. However, IMO we are not talking about minor stuff.
    Sep 2005
    1740
    FYI I did a Search just on this Forum alone, for "Saturn 2" and came up with nearly 4 pages of results, 95 total Threads. I wrote down the names and if they were Good, Bad or Fixed/Refunded/Returned and here is what I got for number. I did not count GME in the Good or Returned group. The Good total was 11 and I went back to July 2017 which is almost before the Saturn 2, and the Bad I came up with 5 total. For what its worth, just numbers. Do your own count. As I have stated before.... people who tend to complain usually post online, happy users do not usually bother.
    Apr 2016
    841
    Interesting. I can count 6 defective machines (including the one I had) without opening a single thread. Taking mine out of the mix, none of the other 5 were fixed to specs. Four owners just made whatever corrections they could manage, and decided to just live with it. The 5th is stuck with a defective machine and appears cast adrift. Bad deals all around.
    I have neither the time nor inclination to go searching around for an exact number of people who reported receiving defective machines. I have more productive things to do. But then, as I've said repeatedly, the number of people involved isn't the point.
    Oct 2019
    Looks like this thread got a bit hijacked, I am curious what the OP decided to build. Did you end up getting an Avid Pro table and use steppers? Which components did you end up using?
    Sep 2005
    1740
    Quote Originally Posted by GME View Post
    Interesting…. but according to the internet FLA has over 500 machines sold. So 6 out of 500 is what percentage?
    Apr 2016
    841
    So, are you assuming that all dissatisfied customers will post their dissatisfaction on CNC Zone? I doubt it. Where are all of the build threads? With respect to the Saturn series, we know that the earlier machines were okay. Later ones were not.
    Let's not forget that FLA also sells extrusion models, which are similar to the Avid standard models (use skate bearings riding on steel plates). In fact, the 500 machines mentioned is in the paragraph speaking to the extrusion-based machines, not the Saturns. Like Avid's machines, 80/20 cuts the extrusions and ships to the customer. Those machines, based upon the design, don't have the same problems as the Saturns, and what problems they have, the purchaser can more readily fix.
    FWIW, I can speak to the FLA extrusion machines. My first machine was one of them. Even with it, I had problems I had to fix. Pretty aggravating. Also, FWIW, I didn't start a build thread, and didn't register my complaints on the Zone. With the clarity of 20/20 hindsight, I should have. Just goes to show that dissatisfaction does not necessarily mean it will show up on the Zone.
    Gary
    Sep 2005
    1740
    Off the FLA website "We have shipped out over 1,000 CNC Machines to customers so far over eight years. Those machines are being used by people to support their dream business, build dream projects, and more."
    Not everyone posts a build Thread, not everyone comes online when they have a good machine to brag. People do complain online however, some over little piddly things, others are are a perfectionist type and will never be happy no matter what, some have real issues. So 6 posted complaints and the guy is still in business after selling a 1000 machines?
Page 1 of 3 123
  1. Slant bed Lathe made from tubular steel: build thread
    By siam in forum Vertical Mill, Lathe Project Log
    Last Post: 08-13-2016, 02:34 PM
  2. Dave's made from samples benchtop router thread
    By kuroguy in forum CNC Wood Router Project Log
    Last Post: 09-22-2015, 02:27 PM
  3. Why hasn't some company made a CNC only head for Bridgeports and clones?
    By Galane in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2014, 03:55 PM
  4. I made the decision and did it
    By mazzy in forum DIY CNC Router Table Machines
    Last Post: 06-11-2012, 06:43 PM
  5. Replies: 3
    Last Post: 11-15-2010, 01:51 AM
