Re: Hyanyang Inverter Wiring and Setup
I think electrically with the 2 live conductors and N connected, the input is directly to a 3 phase rectifier, which means the Neutral has two reverse biased rectifiers WRT the L1/L2.
So then no current will flow in the N at all, this is why you did not see any ill effects when connecting this way. Making it redundant.
Al.
Albert E.
