585,930 active members*
3,575 visitors online*
    Feb 2019
    Best CNC mill parts
    I know this is hard questions but what is the best parts for building a CNC mill?
    What brand of servo motors/system should I use?
    Who makes the best planetary gearboxes for servo motors (lowest backlash)?
    Spindle and motor?
    I know how hard and expensive it is to build a CNC mill, but I will try to build a high quality 5 axis mill.
    Aug 2019
    31
    No doubt about that servo motor is your only option since you want to build a high quality 5-axis mill.
    And the mechnical desgin is a key point.Whether you should or should not use planetary gearboxes depends on the operation load and motion model.
    Last, you need to buy a 5-axis CNC system, that is quite expensive. Recommend FANAC OR SEIMENS.
  1. Replies: 0
    Last Post: 03-13-2018, 06:33 AM
  2. small Mill parts
    By Tennessee in forum RFQ (Request for Quote)
    Last Post: 10-25-2011, 12:30 PM
  3. Sourcing parts for a DIY Mill
    By rchacich in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2009, 04:31 AM
  4. PCB Mill from spare parts
    By Rhodan in forum CNC Wood Router Project Log
    Last Post: 10-29-2007, 05:30 AM
