585,885 active members*
6,253 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Help with a projekt
    Aug 2019
    Question Help with a projekt
    Hi.
    I'm new to everything that has to do with CNC, but i've been trying to figure it out for a couple week now.
    I got hold of a STl model of a Beastmaker 2000, which is a climping grip trainer. I've cut the model into three separate pieces, and triede making toolpaths for each piece.
    From my simulation everythings looks fine, but I was wondering, if one of you guys might take a look at the files, which i made in fusion360, and give me some pointers
    I'm going to cut the pieces at this machine:
    X-Carve, CNC mill | Copenhagen Fablab
    at Copenhagen fablab.
    I haven't yet made the g-code, because i wanted somebode to look at it first.
    The files:
    https://www.dropbox.com/sh/a5p73mqul...u4XNPWuxa?dl=0
    Best regards. Kasper
    Oct 2010
    171
    Re: Help with a projekt
    Kasper,
    I suppose this will work. I don't really see any issues with your cutting methods -- Adaptive is very versatile, and typically works fine on parts like these.
    Did you download these as scans (STL files) or find them somewhere already as BRep files? All 3 of these models show as being steel... is that correct, or will you be cutting them out of other material?
    PM
    Aug 2019
    Hi. Thanks.
    I found the file as an STL an converted it into a .step file. I will be cutting it from plywood, but i haven't figured out how to change the material type
    Oct 2010
    171
    Right click on the body in the browser pane, then select "Physical Material". Select the material out of the possibilities, and drag/drop the icon for that material onto your part.
