585,888 active members*
4,334 visitors online*
Thread: Syil X3
Results 1 to 7 of 7
    Mar 2018
    14
    Syil X3
    Is there anyone who can advise on a spindle control board on a X3, Neil who used to be on this site is no longer around so any help would be apriciated
    Mike
    Jun 2007
    3757
    Re: Syil X3
    Still here. You have s problem?
    Mar 2018
    14
    Re: Syil X3
    Hi Neil
    Tried to conntact you earlier in the year but no reply so assumed you were not around, but thankfully I was wrong, as you are the only one who understands the X3 mill.
    Problem is no spindle power, the front panel readout not lit, no clunk when turn on. As there has been many problems with Syil electronics I am thinking of ditching the existing board.
    Thoughts are powering motor via VFD controled by speed card in turn by Mach3, so have Mach3 working as usual?
    Any thoughts or advice? if you want to comunicate directly e-mail palmermichael[at]talktalk.net
    Regards
    Mike
    Jun 2007
    3757
    Re: Syil X3
    Hi Mike.
    Can you take some photos of the main board so I know which version you have. Do you gave schematics?
    Do not remove front panel with power on. The magic smoke will escape, then make sure the quill us all the way down so you don't damage anything.
    No need to access front panel yet.
    No clunk?
    Means no power to drivers.
    Can be:
    Emergency stop button. Do you use it much? Will kill main relay.
    First off, with power unplugged, tug each wire on connectors.
    What is your level of electronic experience? Multimeter.
    Mar 2018
    14
    Re: Syil X3
    Neil
    To clarify the problem it is only the spindle that has stopped working all steepers work ok, I just turned on and no readout on front panel, I did not use e-stop. I have checked all connections as aware of bad crimps
    I am resonably ok with electronics yes I have a mutimeter, here is pic of board
    Mike
    Jun 2007
    3757
    Re: Syil X3
    Hi Mike.
    I have emailed PDF. Too large to attache! Grrr.
    just updated known errors. Navigate with bookmarks is best. All the information I have, in one place. Enjoy
    Neil
    Jan 2008
    32
    Re: Syil X3
    Quote Originally Posted by neilw20 View Post
    Hi Mike.
    Neil
    Hi Neil, is it possible to send me this document too please? I tried to send you a private message with my email address but you have exceeded your storage quota (popular guy).
    I've got my Syil X3 out of storage (8 years or more) and this might be helpful if I have problems getting it up and running again.
    Steve
  1. Replies: 39
    Last Post: 08-07-2010, 04:59 AM
  2. Replies: 6
    Last Post: 05-13-2010, 12:52 PM
  3. Syil CNC X4 PLUS
    By GWG in forum Syil Products
    Last Post: 10-26-2009, 04:46 PM
  4. Syil X4+ ?????
    By vicknair in forum Syil Products
    Last Post: 01-11-2009, 11:17 AM
  5. Syil X4
    By cvafiadis in forum Syil Products
    Last Post: 05-25-2008, 04:08 AM
