Hi folks,
my problem is the following, I have a MAHO cnc with these drives and the original controller/computer is dead and gone, so I need an idea to figure out how to connect these drives to a Kflop controller , I have the controller and I have also attached the drives with their power supplies and everything and the green led lights up but I am stuck now at figuring out how exactly the wiring works with regards to controlling the drive so that the drive operates the servo motor correctly , both manages rpm and changes direction.
I have sort of found the right wires both that enable toe servo drive thyristor output Ic's and sort of the inputs for +- with which I can change the polarity an so reverse the servo etc but all in all they don;t function properly so something is missing.
Ideally someone here who was worked with such drives could help me out with some knowledge, thanks
