585,759 active members*
4,113 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > Data Error on K1290L JQ Laser Powercut4311
    First, I'm sorry I do not speak English very well
    Second, I need your help !
    I start in the world of CNCs. I bought a used laser cutter, K1290L from JQLaser.
    The seller told me the software used for the machine, powercut 4311. Already, it was not easy to find.
    Then the first one did not find my machine.
    Then, finding another download and reinstalling the program from it, he recognized the machine.
    Unfortunately, I can send the files to the machine, but when the job starts, it tells me Error Data.
    I specify that even a job created directly in the software gives the same error code.
    I think there is a problem with the software but I can not find others, and I do not find how to solve this problem ...
    Ideas ? Did someone have the same worries?
    The seller did not have this problem, and was unable to send me the exact software he was using.
    I thought it could be a software version problem ...
    If somebody can help me .... PPllleeeeeaaaaassssseee !
    Angéline
    Re: Data Error on K1290L JQ Laser Powercut4311
    Probably a bad water flow sensor, or it is wired incorrectly.
    Hi
    I have exactly the same problem machine won't start after loading project and showing error data message.Got no clue how to solve this problem.Did you manage to sort it out if yes please let me know.Power Cut 4311.
  1. error 368 X AXIS : SERIAL DATA ERROR (INT)
    By mattpatt in forum Fadal
    Last Post: 02-24-2023, 02:01 PM
  2. Replies: 1
    Last Post: 04-16-2018, 07:54 PM
  3. Replies: 0
    Last Post: 03-26-2018, 09:23 PM
  4. arc data error
    By slowdigits2 in forum G-Code Programing
    Last Post: 11-25-2014, 10:39 AM
  5. cutting Data won tranfer via USB cable to laser engraving machine comes up with error
    By grahamj61 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-20-2014, 03:09 AM
