585,764 active members*
4,124 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas HRT210 motor replacement
Results 1 to 9 of 9
    Feb 2006
    17
    Just picked up a HRT 210 that needs a motor. It has the sgm-08u2ha12 yaskawa motor. Anyone pick up this model motor from a supplier other than Haas? I have found quite a
    few with the exact same model number, seems like it should be a direct replacement. Anyone have experience with doing this?
    Sep 2013
    326
    EBay seems to have quite a few similars and directs. ...
    https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=+sgm-08u2ha12+yaskawa&_sacat=0
    Quote Originally Posted by astro View Post
    Feb 2006
    17
    Re: Haas HRT210 motor replacement
    I've been checking out all the ones on ebay. Seems to be a bunch in Hong Kong. Looks like they are the exact same models
    Jun 2003
    1365
    as you've already found, plenty on fleabay. Make sure you get the correct part number. It's more common to have a different encoder on the ebay options.
    Feb 2006
    17
    Hwo do you tell which encoder it has other than the model number? Is it in the O/N or S/N number? There is no separate encoder part number.
    Jun 2003
    1365
    https://www.yaskawa.com/delegate/get...E-S800-16E.pdf
    page 31
    "2 8192 P/R incremental" sgm-08u2ha12
    Oct 2004
    178
    have you considered getting your motor fixed? I've used Precision Electric Service in the past with great results.. 800 732 4695 At least you would know you have the right motor!
    Feb 2006
    17
    Quote Originally Posted by greggv View Post
    I'm looking into getting it serviced now
    Feb 2006
    17
    I had the motor into global electronic services. The motor was supposed to be rebuilt but my haas doesn't seem to see the encoder. Checked continuity on all the cables. Sent motor back and it came back the same way.
    Should the encoder read on the haas display when the servo power is shut off? I'm guessing yes because I turned one of the ball screws and the numbers on the controller changed. So as far as I can tell I get no encoder read from the motor, but the re-builder says everything works. Anyone got any ideas
  1. tail stock for haas hrt210 for sale
    By ach59 in forum Haas Mills
    Last Post: 01-29-2011, 03:28 AM
  2. Haas HRT210
    By rrbmachining in forum Haas Mills
    Last Post: 06-06-2010, 06:16 PM
  3. HAAS HRT210 wiring diagram
    By jcassidy in forum Haas Visual Quick Code
    Last Post: 03-11-2010, 09:34 AM
  4. Installing / Removing HAAS HRT210 4th AXIS
    By glenn105 in forum Haas Mills
    Last Post: 01-21-2010, 07:49 PM
  5. Haas VF with HRT210 indexer, M21
    By Talisman in forum Haas Mills
    Last Post: 10-23-2009, 04:02 AM
