Hy did you solve the problem?
I suddenly lost the power on the control panel, I checked the fuse on the power supply behind the control panel and the fuse was blown. I replaced the fuse but I am not getting any voltage on output pins.
There is a 6 PIN output with wires.
RED/WHITE/BLUE/RED/WHITE/not connected.
The PSU should output +5V(3A)/+12(0.4A)/-12V(0.4A) but Im not sure which voltage goes on which pins.
I was thinking to use PC PSU instead but I need to know which voltage goes on which pin.
If anyone could help that would be awesome.
