585,949 active members*
4,131 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > MAZAK T32-2 Control panel suddenly died
    Jan 2013
    73
    Hy did you solve the problem?
    I suddenly lost the power on the control panel, I checked the fuse on the power supply behind the control panel and the fuse was blown. I replaced the fuse but I am not getting any voltage on output pins.
    There is a 6 PIN output with wires.
    RED/WHITE/BLUE/RED/WHITE/not connected.
    The PSU should output +5V(3A)/+12(0.4A)/-12V(0.4A) but Im not sure which voltage goes on which pins.
    I was thinking to use PC PSU instead but I need to know which voltage goes on which pin.
    If anyone could help that would be awesome.
    Jan 2013
    73
    Re: MAZAK T32-2 Control panel suddenly died
    If anyone can check with multimeter output voltages on the CNP82 connector that would be great.
    I tryed to trace the leads and came up with output but Im not sure if its right.
    Aug 2019
    339
    Quote Originally Posted by mlinkadelsol View Post
    In a meantime drag your question over to Practical Machinist . com. Lots of folks there would still have the Maintenance Manual and could snap a few pics of those schematics for you.
    Jan 2013
    73
    Quote Originally Posted by Mecanix View Post
    I did post on both forums.
    Thank you.
  1. Need help on mazak V-550 mill with m32 control panel.
    By Spangler1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-12-2018, 08:13 PM
  2. Mazak M5N with T32-2 Controller battery died
    By MONKEY2TO2 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2014, 11:21 PM
  3. FH6800
    By jimica in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-15-2013, 10:49 AM
  4. Died Control
    By akram in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-07-2008, 10:42 AM
