585,930 active members*
3,869 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > More position repeteability sensor when homing?
Results 1 to 6 of 6
    Dec 2016
    5
    Please, I am designing my own CNC Milling Machine. Now I need to be clear about Home Position. I will use stepping motors with open loop control. No encoders. What is the more accute sensor for home position?. I want to go always to the same position whenever I switch off and on my machine. I have read thar mechanical switches (lever or plunge type) and inductive are not good solutions.
    Thanks in advance!
    Best regards!
    Dec 2013
    5717
    Re: More position repeteability sensor when homing?
    It depends on the mechanical switch, there are precision switches available.
    https://www.automationdirect.com/adc...limit_switches
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2008
    644
    Quote Originally Posted by felixpico View Post
    Thanks in advance!
    Best regards!
    Another way with inexpensive switches is to combine a linear switch _and_ a proximity sensor or optical switch that detects a slot on
    a disk mounted to the step motor shaft. With just a 3.25" disk (~10" in motion at disk edge per turn) you get a ~50x improvement in switch
    accuracy assuming 0.2" (~5mm)/ turn screws
    Dec 2016
    5
    Thank you very much for your answer!
    Dec 2016
    5
    Thank you very much for your answer PCW_MESA!
    Dec 2016
    5
    And what about this type of 5volts opto? How accute are they? Do anyone have any opinion about "Hall effect magnetic sensor"?
    Thanks in advance!
  1. Position sensor ideas?
    By LordyGordy in forum Calibration / Measurement
    Last Post: 05-21-2016, 08:28 PM
  2. Replies: 2
    Last Post: 05-14-2016, 09:00 PM
  3. PCNC1100 Belt Position Sensor?
    By btu44 in forum Tormach Personal CNC Mill
    Last Post: 06-09-2012, 10:00 PM
  4. Hypertherm Powermax45 Ohmic Sensor as Homing Switch
    By Voodoo Vintage in forum Hypertherm Plasma
    Last Post: 01-31-2011, 02:05 PM
  5. Accurate homing switch and sensor for stepper
    By snoopy27 in forum CNC Machine Related Electronics
    Last Post: 09-01-2008, 04:48 AM
