586,024 active members*
4,299 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Aerospace CNC Machining parts problem
    The materials and manufacturing technologies of Aerospace CNC Machining parts are developing toward high temperature, lightweight, compounding, integration, high efficiency, and low cost. The manufacturing technology of complex structural components such as aircraft casings and integral blade disks of aviation engines is constantly improving. Manufacturing technology has evolved from advanced manufacturing to high-end manufacturing. Aviation complex structural parts processing technology involves CNC machine tools, advanced tools, efficient programming, CNC machining simulation and cutting process and parameter optimization.
    Processing of typical complex structural Aerospace CNC Machining parts
    Aerospace CNC Machining parts use a large number of difficult-to-machine materials and composite materials such as titanium alloys and high-temperature alloys, and their machinability is extremely poor. The parts of the casing and the whole leaf disc are complex, and it is easy to produce machining deformation. The dimensional accuracy and technical requirements are difficult to guarantee.
    The machining of the integral leaf disc type is a typical five-axis CNC milling. The airflow passage between adjacent blades is narrow, and the surface between the blades is prone to interference during processing, which has extremely high requirements for the tool path. Because of the easy interference, it is necessary to test the accuracy of the machining program by simulation before actual machining.
    Whole leaf disc processing simulation steps:
    1 In the VERICUT environment, call the constructed five-axis machining center model. Call machine files, CNC control files, and tool magazine files.
    2 Introduce the blank STL model file of the whole leaf disc into the component tree and set the workpiece coordinate system.
    3 Transfer to the NC program and define the tool list.
    4 Check the correctness of the NC program. Set the recognition color such as collision, overtravel and interference to check the interference between the machine tool, the tool and the fixture.
    5 Impeller simulation results analysis, check the parts for undercut, overcut, confirm whether the program can be used.
    The machining of complex structural parts of aero-engines relies on innovations in process methods. Its manufacturing level directly determines the performance of the aero engine.
    ebi-part.com provides rapid prototyping service, Aerospace 3D Printing, Aerospace injection molding, Aerospace CNC Machining, low-volume, on-demand. no MOQ, fast delivery free design.
    Sep 2020
    Re: Aerospace CNC Machining parts problem
    Enabling WP_DEBUG will cause all PHP errors, notices and warnings to be displayed. This is likely to modify the default behavior of PHP which only displays fatal errors and/or shows a white screen of death when errors are reached.
    Showing all PHP notices and warnings often results in error messages for things that don’t seem broken, but do not follow proper data validation conventions inside PHP. These hill climb racing warnings are easy to fix once the relevant code has been identified, and the resulting code is almost always more bug-resistant and easier to maintain.
  1. Replies: 0
    Last Post: 03-13-2018, 06:33 AM
  2. Precision Machining-Fab-Design-Composites. Specialize in Aerospace-Defense-Energy
    By CNMPrecision in forum Manufacture Company Listing
    Last Post: 02-12-2017, 11:24 PM
  3. Aluminium Parts Machining(China CNC Machining)---www.inhacnc.com
    By youngchon in forum News Announcements
    Last Post: 10-31-2013, 03:10 PM
  4. Machining anodized parts or anodize after machining?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 03-12-2006, 06:22 AM
