584,814 active members*
5,303 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Vertical Lines in Model
    Apr 2005
    1268
    Hey Guys;
    I'm finally getting back to the shop and doing some work but have came across a very weird problem. I'm cutting an inlet for a horse theme paradise box and am getting shaded vertical lines in my carving. They appear to be slight increase in Z height almost like oscillations. Has anyone experienced this before. I was able to decrease the problem by lowering my acceleration but it is still there. I've tried carving from different angles including 0 (horizontal), 90 (vertical) and even a 45° angle and the lines are still showing up at the apparent same frequency. I'm wondering if my z axis Gecko 320 may be chattering or oscillating. The specifics are: Mach 3 control, Gecko 320's, Chinese balls and screws on a very sturdy aluminum frame. I'm generating the code with Aspire 4.0.
    Any suggestions or help will be greatly appreciated.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Re: Vertical Lines in Model
    I answered this somewhere else that you posted it, but I'm pretty sure its due to vibration or resonance in your machine.
    Apr 2005
    1268
    Hey Gerry;
    Yup thanks for the answer. The resonance you identified is most likely the problem but I'm fishing for an idea of what would cause it. I'm thinking the Gecko on the Z axis but again, I'm fishing. It's an old 320 thus is somewhat dated but I was kinda hoping someone has seen this before and maybe found a way to adjust it out.
    It may be wishful thinking but I don't want to switch out the control system and still have the problem. Also, I'm thinking that if the issue is structural, it would appear on the peaks of the models and not just the flat surfaces. It also could be the g-code math but since it is Aspire, I doubt it.
    Regardless, many thanks for the response.
    Bill
    billyjack
  1. Heidenhain tnc 430 Monitor problem vertical lines
    By wojtekthx in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-05-2019, 11:37 PM
  2. Vertical lines
    By popspipes in forum SprutCAM
    Last Post: 03-22-2017, 03:42 PM
  3. Vertical lines in finished part
    By popspipes in forum Tormach Personal CNC Mill
    Last Post: 02-23-2017, 05:25 AM
  4. RDWORKS banding(vertical lines?
    By tigox in forum Laser Control Software
    Last Post: 10-28-2016, 02:48 PM
  5. vertical lines on display screen (Fanuc 18M)
    By sansgp in forum Mori Seiki Mills
    Last Post: 01-19-2013, 12:18 PM
