585,741 active members*
5,359 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Cast heat resistance stainless material cutting
    Apr 2019
    Hello,
    I'm having trouble turning (Cast heat resistance 25cr - 20ni stainless steel per idm - 8393.) This material has a high crome and nickel content. The problem I'm having is keeping consistency with the tight dimentions has anyone had any experience cutting this stuff? Any advice at all will be appreciated.
    Thanks.
    Sent from my SM-G950F using Tapatalk
    Aug 2015
    108
    Re: Cast heat resistance stainless material cutting
    Try Mitsubishi inserts. VP10RT is the grade we used to cut Inconel. I would stay with inserts in the S group for heat resistant alloys.
    We made a tight tolerance bushings on a ST10 and the finishing inserts lasted maybe 10 - 20 parts before they wore out. The roughing inserts lasted 5 - 10 parts, but Inconel has a much higher nickel content than what you're turning.
    Apr 2019
    Thanks for the info. Did you run without coolant that was something that was suggested also I take it you had a low spindle speed.
    Regards,
  1. speed and heat for material
    By nbk808 in forum PlasmaCam
    Last Post: 03-19-2012, 03:25 PM
  2. RFQ: Cast Stainless Steel Turbo Manifold
    By BEfab in forum RFQ (Request for Quote)
    Last Post: 02-19-2012, 09:13 PM
  3. Heat treating and ageing cast aluminum
    By Doug Schwochert in forum Casting Metals
    Last Post: 08-04-2010, 09:36 PM
  4. Heat treatment of stainless steel.
    By zoeper in forum MetalWork Discussion
    Last Post: 12-18-2008, 03:19 PM
  5. Cutting heat proof material. Is it safe?
    By Robin Hewitt in forum MetalWork Discussion
    Last Post: 10-25-2007, 07:47 PM
