585,717 active members*
3,917 visitors online*
IndustryArena Forum > Community Club House > Environmental / Alternate Energy > There *must* be a better way to compare batteries (lead and lithium in particular)
    Mar 2005
    266
    I was looking at electric scooters and decided to see the difference between lead acid and lithium... big one is weight with lithium being by far the less heavy the next big one is price with lead acid being the big winner by being less expensive.
    some important points...
    lead acid can at least potentially be reconditioned by just about anyone with some knowledge the lithium can't
    lead acid gets recycled I am guessing the lithium doesn't
    lead acid makes a much cheaper powerwall...
    both must be relatively slow charged or they die but lead acid takes much longer to get charged
    lead acid batteries come in tough containers but many lithium batteries can't so much as get nicked without failing (the lead acid could also be repaired?)
    the comparisons between lead acid and lithium when comparing weight are 100% unfair IMO. Its apples an oranges to compare an old battery contruction method like what is used with many lead acid batteries with the new ones used with lithium batteries? Can a lead acid be made like lithium batteries? I realize lithium is *very* light weight in comparison to lead but its also being spread out incredibly thin while the lead acid batteries have thicky spongy plates and a ton of electrolyte. Would the comparisons between weight and power be so extreme if lead batteries were made more consistent to the way lithium batteries are made?
    Mar 2017
    411
    Re: There *must* be a better way to compare batteries (lead and lithium in particular
    Don't forget. https://www.bing.com/images/search?q...C6&FORM=IQFRBA
    This usually doesn't happen with lead acid.
    Jan 2018
    1516
    Quote Originally Posted by maxspongebob View Post
    And they're on about banning engine cars and going all electric by 2040 over here!! NO WAY!
    1: Within 10 years you'll have a landfill the size of Ireland full of lithium batteries. So much for the Carbon footprint!.
    2: You'll be lucky never to be in a fireball.
    Anyway.
    Lead acid also poop themselves pretty quickly if you constantly discharge them below 50%. Lithium Ion can comfortably go a lot lower.
    As for charging generally lead can comfortably go at 0.1C and Lithium at 1C charge rates. It's a big difference.
    If you know what you're doing then for good power to weight try lithium polymer.
    Oct 2020
    For portability, lithium is preferred, but if weight is not an issue, lead acid would be choice.
    Work is currently under way for an aluminium/air battery. Not sure on the specs for these though.
  1. Lithium batteries
    By Riverrunner in forum CNC Machine Related Electronics
    Last Post: 12-24-2017, 11:27 PM
  2. Machining of Aluminum Lithium
    By JMS1959 in forum MetalWork Discussion
    Last Post: 11-05-2011, 11:03 PM
  3. Lithium Grease?
    By Robotics Guy in forum DIY CNC Router Table Machines
    Last Post: 08-20-2010, 02:30 AM
  4. Trying to machine Lithium Disilicate
    By JayH1119 in forum Glass, Plastic and Stone
    Last Post: 06-09-2008, 10:44 PM
