585,973 active members*
3,870 visitors online*
Page 2 of 2 12
Results 21 to 31 of 31
  1. #21
    Re: Help G41 doesn't work for multiple offsets!
    [QUOTE=BehemothDT;2319064]Shineworld, do you have the tool diameter loaded in tool table for tool 120?
    Yes, I've used a tool diameter of 1.2 in.
    To use 1.25 in I need to change G41 mode from Normal to Easy Lead In mode otherwise the g code compilator sign "Cutter gouging with cutter radius comp" error.
    In RosettaCNC is possible to define 3 types of G41 compensations strategies: NIST, Easy Lead In and Normal (the default mode).
    Every mode manage differently the gouging questions.
    For CAM like Fusion 360 Easy Lead In is the right way.
    For manual gcode is better to use Normal way in which gouging is managed better
    NIST mode is the more strict way and implement the NGC274D-NIST standard.
  2. #22
    Mar 2014
    35
    Shineworld, I thought you had run my code in mach3. I enlarge the picture and squint my eyes and see the RosettaCNC at top.
    Im very interested in RosettaCNC, but can't find much info from users. They have a cool video of some 3D embossing and such.
    I went to their site and didn't see prices. I really want something that will go with most of my already installed electronics and hardware. I can migrate to Mach4 Hobby for about $300.
    I only need 4 axis.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  3. #23
    @DehmothDT,
    I'm in software development team of RosettaCNC so I can reply to some your questions.
    RosettaCNC is a brand of QEM srl a 40 years old Italian factory which produce PLC's, custom CNC's and instruments for industrial applications,
    so RosettaCNC is an Industrial CNC with all required certificates.
    The prices are not available on web for many reasons.
    Price depends by hardware/software options and quantities but you can request a price with web form in rosettacnc web site just placing a valid email and your needs.
    Just for info a 4 axis RosettaCNC-A start from 399E to below 2000E of RosettaCNC-B with RTCP, OPC.UA, EtherCAT & step/dir outputs and other features.
    The product is not knowed outside of EU at moment.. will be.
    I'm just ending the full management of Imperial system in UI to reach US needs.
    The system is composed of PC software and CNC board.
    PC software is used only for UI interface, G Code compiling and board settings.
    CNC board is based on proprietary RealtTime Operative System and manage itself interpolations, I/O, etc,
    so PC requirements are very little because all of job is done by CNC board.
    The CNC manage Fanuc-B macro language with some extensions.
  4. #24
    Attachment 426828
    this is what I'm getting in mach 3
  5. #25
    Mar 2014
    35
    Quote Originally Posted by metalmayhem View Post
    Attachment 426828
    Did you input the tool diameter 1.25" in the tool table for #120?
    If diameter is set at 0.0" mine looks like yours.
  6. #26
    i was playing around with it and I see what you mean . I put 1.25 in the wear earlier , when I put it in diameter then it's pretty whacked out
  7. #27
    15362
    You would never put 1.25 in the wear dia that would mean the tool diameter would be 2.5 dia
    D the tool diameter=1.250 tool wear is only how much you want to add so if you added 0.010 this would add 0.010 to the diameter of the tool
    Mactec54
  8. #28
    tell me something I don't know
    I'm just trying to repeat what was suggested and I happened to put the suggested value in wear rather than diameter
  9. #29
    The Wear offset column in Mach3 doesn't do anything at all.
  10. #30
    I played around some and chopping up the code into sub routines for the finish paths resolves the problem on multiple work offsets
  11. #31
    15362
    I don't know if it works or not I never use the wear offset
    But I do use a P value in the code and it work just fine
    Just did this for kicks and giggles these are just straight lines, and it works as programed what ever the P value is it will offset the tool by that amount
    G90 G17 G40 G80
    G21
    G54
    G0Z1.
    G0 X0 Y0.
    S1000 M3
    G1 G41 P0.05 Y.5 F25.
    X1.5
    Y.6
    X2.0
    G40 Y1.25
    M5
    M30
    Mactec54
Page 2 of 2 12
  1. multiple work offsets
    By poster in forum Mastercam
    Last Post: 02-21-2013, 03:28 PM
  2. Multiple Work Offsets
    By 9 1/2 in forum Mastercam
    Last Post: 11-15-2009, 11:28 PM
  3. multiple work offsets in MCX
    By bob1112 in forum Mastercam
    Last Post: 10-01-2008, 02:17 PM
  4. Multiple Work Offsets
    By PinMan in forum BobCad-Cam
    Last Post: 06-06-2008, 10:41 PM
  5. multiple work offsets
    By rbest27 in forum Surfcam
    Last Post: 01-25-2007, 10:02 AM
