585,759 active members*
3,895 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Autodesk Post Processors > Mazak Integrex IV matrix control post processor for Fusion 360
    Really would like to any ones advice on a post processor for Fusion 360 to out put code for a Mazak Integrex Mark IV with matrix control. This particular Integrex is programmed with turning in mind first and milling secondary. Other models are Milling first with turning second. As I understand it there are differences between the output. I am looking for recommendations, opinions, ect.... on whether we should be trying to program this machine from Fusion 360 which we are now using in the shop as our CAD software. Also if anyone has any information on how to get a post or has dealt with a company to provide a post for Fusion 360 please also respond.
    Chad
    Multi-Tasking Machining - Customer savings, and shorter lead times!
    www.northernmachininginc.com
    Apr 2015
    327
    Re: Mazak Integrex IV matrix control post processor for Fusion 360
    Hello,
    if it is still actual.
    You can let me know on [email protected]
    Im a programmer with focus on a postprocessor coding
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
  1. Post processor for Mazak Integrex!
    By northernmach in forum EdgeCam
    Last Post: 06-12-2015, 07:52 AM
  2. power mill post processor for mazak matrix nexus
    By raydane6 in forum PowerMILL
    Last Post: 06-05-2015, 04:07 PM
  3. How to Park Lower Turret mazak Mark IV Integrex Matrix Control
    By SteveCADCAM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-14-2012, 03:03 PM
  4. How to run XC milling on Mazak Integrex Mazatrol Matrix
    By Riddersholm in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2012, 08:44 AM
  5. Mazak integrex 200-IV mazatrol matrix alarm 1281
    By bor32 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-02-2010, 07:59 AM
