0 active members*
4,653 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > New to CNC Machining - What type of Quick Chage Tool Holder is this?
    Sep 2019
    I am brand new to CNC machining and I have a Lagunmatic 310 with Dynapath Delta 20 controls that I recently acquired. It has a quick change tool holder on the spindle and I would like to buy some additional tool chucks but I am unsure of what type/style of tool chucks these are. I've done some research and I thought these might be NMBT40 to CAT40 chucks but from the pictures i have seen thee don't look like either of them. I was hoping someone could ID these to put me on the right path.
    Thanks!
    Dec 2013
    5717
    Re: New to CNC Machining - What type of Quick Chage Tool Holder is this?
    That looks like a Kwik-Switch tool holder. But remove the upper nut and I'll bet you find a standard NMTB 40 taper once you remove the Kwik-Switch adapter.
    Jim Dawson
    Sandy, Oregon, USA
  1. Bridgeport boss 6 quick change tool holder not holding tool properly.
    By TBCind in forum Bridgeport / Hardinge Mills
    Last Post: 04-04-2017, 06:56 PM
  2. Pause machine to chage tool ??
    By Lasercutouts in forum Uncategorised CAM Discussion
    Last Post: 02-03-2017, 01:01 AM
  3. QUICK CHANGE TOOL HOLDER RACK
    By hmoore01 in forum Bridgeport / Hardinge Mills
    Last Post: 03-11-2014, 03:15 PM
  4. What type of tool holder is this???
    By Michael Turner in forum CNC Tooling
    Last Post: 11-09-2009, 04:24 PM
  5. Designing a quick change tool holder.
    By DeusExMachina in forum Taig Mills / Lathes
    Last Post: 05-26-2009, 12:43 AM
