585,762 active members*
4,096 visitors online*
Page 1 of 2 12
Results 1 to 20 of 34
    Jul 2019
    8
    Fixed Gantry Build
    Hey all,
    Planning on building a fixed gantry build designed to cut plastic/wood/aluminum with reasonable precision in a relatively small form factor, and at a price point around $1500. At this stage I have a basic plan laid out, and am looking for feedback, but this thread will serve as the "build thread" for the project as well.
    THE DESIGN
    The base of the machine is a 24" x 24" Cast Iron surface plate, that I got on a good deal in the local classifieds. The plate has the usual light scratching, but the previous scraping marks are still easily visible, with no discernible warpage as measured with a precision straight edge and one thou feeler gauge. I know granite is very popular for higher end DIY builds, and isn't susceptible to corrosion and has better vibration characteristics, but the plate was super cheap, and I can readily drill/tap it without the need for special bits/inserts. I'd estimate the weight in the 150-160 lb range, and it should be plenty sturdy enough for the things I plan to machine. In addition I believe the CI plates are a bit more thermally stable.
    The X gantry is 3" x 6" 8020 extrusion that I plan on filling with epoxy granite. I debated going with HSS, but decided that trying to get it machined around here would be tough with limited options, and it would be relatively easy to swap out for something else in the future is need be. The gantry will sit on 2" x 4" rectangular HSS. I haven't decided on a wall thickness, but probably something between 1/4" and 3/8". On the top will be a 3/8" plate that the extrusion will sit on along with support brackets (not pictured) on either side as well as the back. I had to get a bit creative on the mounting to the surface plate, and I'm afraid this will be the weak link if I encounter any serious vibration/deflection issues. It again will be 3/8" plate, fastened on both the top and side surfaces. I'll likely extend the plate in the Y axis to improve longitudinal stability. Although only one bolt is pictured I plan on securing it with 4 7/16" grade 8 bolts on either side, and once I get everything exactly where I want it I may consider pinning it with some dowels.
    All of the rails are offshore 20mm HIWIN clones, and while I know there are better options out there it's just not in the budget. These should provide a reasonable amount of rigidity, and for the moment will get me in the game. The X axis will be 750mm (600mm rails in the model at the moment) which should allow for just over 600 mm of travel. The Y axis are 500mm, and though shorter than the plate would allow the machining table I plan on using is 12" x 24" x 1/2" aluminum plate, and 500mm rails net me over 300mm of travel. The Z axis is loosely laid out in the model, but I'm considering purchasing a premade axis off of ebay that uses 15mm rails, and looks to have decent machine work.
    As for motion control the X and Y axes are setup with 16mm dia. 10mm pitch ballscrews. the consensus seems to be that this is a solid middle ground between resolution and movement speed. The Z axis is setup for a 5mm pitch ballscrew, as movement speed isn't as critical in this axis. For motors I've gone with offshore 2.2 Nm NEMA23 steppers driven by generic stepper drivers and a 12.5 amp 48 V power supply with shielded cable throughout. I've gone with MACH3 as the control software and have a super cheap USB breakout board for now just to play with. It doesn't have much in the way of I/O and I plan on using inductive limit switches, and will require I/O for the cooling and spindle so a final board will be decided in the future. I've already purchased the basic electronic setup, and have successfully tested all 3 motors in MACH3.
    The spindle will be a generic Chinese 2.2Kw unit unless a used or new old stock unit falls in my lap. For the time being this is on the back burner until I get some axes in motion.
    For the moment I've made a few purchases of parts that so far includes:
    Stepper motors
    Drivers
    Power supplies (24V and 48V)
    USB breakout board
    Shielded cable
    X, Y, and Z axis rails
    X, Y, and Z axis ball screws
    Surface plate
    Any and all feedback is appreciated. I have a large amount of experience in CAD (Catia, SW, SE, Fusion360) but very little experience in the CNC world. 99% of the CNC I've done has been waterjet cutting on OMAX's and a little bit of 3D printing. This has thus far been a daunting, but rewarding learning experience, and I'm excited to make my first chips!
    May 2005
    3920
    Re: Fixed Gantry Build
    Looks like you put a lot of thought into this. I have a few comments to ponder!
    First Mach 3 is getting very old and has been unsupported for a very long time now. There are many options these days for a hobby machine. This isn’t a big deal as retro fit at a later date isn’t too difficult. This is just a standard warning for people that might not be familiar with the state of Mach3.
    As for the machines table, I’d turn it 90 degrees and flip the linear rails. This would allow for more rigid mounting of your gantry supports and frankly a lot less machining / fabricating. Your table can then be as long as required to get your working area.
    Speaking of the gantry if you are going to make those complex supports then you most likely have access to build the gantry beam out of steel sections. Your surface plate gives you a good starting point. As such you might as well make the machine as stiff as the budget allows and the plate can support.
    If you do go 8020 I’m not sure filling the cavities will do much for you. The big problem with extrusions is the thin webs where you mount the linear rails. In that regard there is a huge difference in the various extrusions available from manufactures. If you go the extrusion route prefer a heavy series.
    Jul 2018
    6325
    Hi UC - Filling the extrusions with "epoxy granite" is an expensive exercise and does not improve performance relative to the cost and effort. Your much better off using steel or aluminium heavy square tubing (unfilled) . Looking at your images I'd make the connection to the base plate a lot stiffer. Peter
    Jul 2012
    102
    I would argue that any unfilled/unbraced square section is unsuitable for a gantry. Torsional stiffness of hollow tubing is poor.
    I think epoxy-granite is a good way and relatively simple way to stiffen one. At least for me it's easier than soldering a diagonal plate or rebars inside a tube.
    Apr 2005
    629
    Here is my thought...
    Large industrial machines that are configured like this are called either a Bridge or Double Column machine. Gantry machines are "moving bridges".
    Just a pet peeve of mine.
    Otherwise the design looks good. I see one thing I would change right away and that is the single screw you are planning to hold the column to the base with. One screw always creates a pivot point, even if the object has registration surfaces. I would highly recommend using two screws.
    You may also want to show the final design once you have the Z axis drive system in place.
    Chris D.
    Jul 2019
    8
    Thanks for the feedback everyone! I'll try and respond to everyone's points!
    Wizard:
    I haven't sunk but $20 into the mach3 board and have just played around with their demo software, so I'll be sure to check out the CAM forums here to see what everyone recommends.
    As for flipping the table 90 and switching the rails, if I'm reading this right you're saying to put the 750mm rails on the surface plate and 500mm rails on the bridge? that'll leave about 75mm of rail hanging off of either end. Would that be an issue? I'll try and draw something up in Fusion tonight based on what I think you're saying and post back.
    I certainly could have the bridge made from steel. There's a local yard that I can buy by the pound, and find just about any kind of structural steel you can imagine. My concern is finding a place to get it machined. I know of a couple machine shops around here but they're more focused on large volume parts. I'll have to stop by the scrap yard anyway and maybe I'll take a look at what they have and give some local machine shops a call.
    Thanks to both Wizard and peteeng on the epoxy granite info! In term of expense is there anything wrong with getting a marine epoxy and play sand? I've seen a few builds use that with success. More than strength I'm looking to cut down on vibration, but if it won't be much of an issue then I won't bother.
    Thanks to Chris for the nomenclature correction! Precision of language is important! Only one bolt hole was depicted as more of a reference. What I plan on doing is using 4 7/16" fasteners on each side, and I've updated the model to reflect that below. I still haven't decided if I'll go with the pre machined Z axis. I'm thinking I will initially, and maybe machine a custom one once I get the machine running on the pre-built. After that I can use the pre-built on a future CNC plasma table
    Apr 2004
    5735
    This looks like a pretty good design, but you might want to rethink some details. Mounting the Y-axis rails like that will be problematic; you're depending on T-nuts to hold the rails absolutely straight, flat and parallel to each other, which is a lot to expect. I'd suggest making up a plate that would mount to the extrusion, with channels milled into it, which would provide a flat base for the rails and ledgers they can rest against to ensure straightness.
    Also, those red-colored mounts between the base and the extrusion will have to be machined to exactly the same height and absolutely square, or the whole thing won't cut straight. Do you have access to a milling machine? I'm not seeing this working too well without one.
    Andrew Werby
    Website
    Jul 2018
    6325
    Hi UC - epoxy filling success is gauged by what? Sure you can do a successful fill but did they check the harmonic performance before and after the fill? Vibration is caused by the motors so you can isolate the motors more effectively then by modifying the structure. Learn about machine vibration vs doing stuff because people do it.
    "GME's New 80/20 CNC Build - My Design" a lot of effort was done in this thread (later part page 7 onward) and discussion about vibration, will help you in this design. Peter
    Jan 2008
    1529
    Peter, a lot of vibration can be due to steppers, but certainly not all.
    Material cutting can induce problem vibrations resulting in chatter and poor surface finish. This is usually much more obvious with metal machining than wood.
    There are a plenty of papers on use of epoxy granite in machine tools.
    I agree that quantifying the effect is non trivial for the hobbyist and usually not done.
    The same can be said of much of DIY machine design. Many design choices are made based on lack of understanding, what looks good etc rather than relatively simple good engineering principles.
    Jul 2018
    6325
    Hi Pippin - Yes agreed, but chatter is a machine design shortcoming just as machines that vibrate are a shortcoming. Epoxy granite construction is interesting but I can't see it as an economical solution to machine building. It certainly is damp and heavy which solves various problems. In the end it's up to the Maker to decide on the construction philosophy and to prove the pudding (or not). The Maker has various objectives, budgets and viewpoints with any machine and I encourage people to keep making things. I've been building various machines for 30 years and I like to feel I'm still getting better at it and I try to share the knowledge gleaned from 30 years of successes and failures, mine and others. Happy to help Peter
    May 2008
    1185
    A few things.
    The 20mm rails are fine but the carts might need over sized balls to be tight.
    I just re did a few 16mm rails and it really worked well. I think they run the same size balls so if you have standard preload carts I have a few thousand over sized balls.
    Same with the ball screws. I did not see if your going double nuts but if you have single you will want to re pack them for positive preload. It is easier to just get double nuts and shim them.
    On the gantry you might be just as well going with steel. I have a hunk of 2.5" X 4" 1/4" wall I might be able to surface for you and it will be much stronger. This hunk is a little heavy but most any steel part will be much stronger.
    On the gantry ball screw, it is best to put it closest to the point of load which is your cutting tip. It will work better on the bottom or between the rails.
    Nice looking model BTW.
    youtube videos of the G0704 under the name arizonavideo99
    May 2005
    3920
    UCBones.
    I think we have mis communicated here in a couple of ways.
    With respect to expiry granite filling aluminum T-Slot extrusions, there are several problems I will try to clear up.
    1. The fill is concentrated at the center of the structure so it doesn’t offer a lot for the effort involved. It is a bit more difficult than stuffing sausage due to the small crops sections in those hollows.
    2. If you look closely at the extrusion cross section you will notice that there is nothing but what amounts to sheetmetal holding up one side of the T-Slot. How important to you that this is to you I can not decide but it is a mechanically weak design. More so how weak it is varies a lot with the extrusion supplier and the series of extrusion purchased.
    3. People seem to want to believe that Tslotted extrusions make mechanical assembly easier, I don’t buy into this at all. This especially on a gantry beam with the rails relatively close together. As mentioned above this is often addressed by a properly machined plate to mount the rails on that is then mounted on the extrusion.
    As for the table, hopefully this clears up what I meant:
    1. Turn the table 90 degrees
    2. Instead of you current linear rail mounting arrangement flip the rails and bearing blocks over.
    3. This puts the rails on the table and the bearing blocks on the surface plate. No other axis need change.
    4. This does allow you to move the gantry supports (columns) in to make for a more rigid mounting to the surface plate. I really don’t like the current arrangement at all, especially running screws into the edge which risks break out.
    5. Moving the gantry supports in board a bit makes it far easier to manufacture something that doesn’t require machining. Your drawings pretty much indicate parts that will require a mill to get right.
    6. No matter what your u buy, aluminum extrusions, steel tubing or something else, they will ship in a raw form with no guarantee of the various faces being square. You can design in provisions to help with alignment or hope that a high quality machining job gets things as square as needed. How square is needed is another issue which only you can answer.
    In any event you have a nice start scoring that surface plate. I just really don’t like how the up fights for the gantry beam are implemented. If you want to do this build without the use of a machine shop then you need easy ways to overcome the lack of precision in those uprights. There are a couple of ways to do this but you might want to put grouting the beam to the uprights.
    Remember the goal here is to build machines that meet your expectations as far as performance goes. We can’t really guess what your expectations are and, so we offer advice based on our best guesstimate of what you need.
    About Mach 3, if it becomes too much of a problem the switch to another step and direction implementation isn’t really that big of a deal. I only bring it up because of its unsupported nature and the fact that we have a lot of good to better options these days. Mach 3 has along history in the hobby world thus is widely known, but things change. Personally something that is supported and decoupled from the PC is the way to go these days.
    Jul 2018
    6325
    Hi Jack - There are 100's and 1000's of successful extrusion gantry machines out there. Consider 1) that the inside of the extrusion is a small % of the total geometric inertia of the section so filling it with anything does not significantly improve its geometric inertia. 2) epoxy is 3.5GPa stiffness and Al and sand is 70GPa (granite is 35Gpa to 60Gpa depending on type) so as the epoxy granite is 50% by volume epoxy at best it does not contribute sufficient material stiffness to help either. 3) it does make it heavier which does help vibration but not its rigidity.
    Saying torsional stiffness of square tubing is "poor" compared to round is circumspect. If a round and square tube of same envelope are compared the sq tube is 170% stiffer in torsion then the round one. See attached, the Dia100x6mm thick round tube is far less stiff in torsion and bending then the 100x100x6mm sq tube. For a gantry it can't be too big. Most people underestimate the size required to do the job. Make the tube or extrusion big enough in the first place and no rectification is needed. Successful rectification is doomed if the section is too small no matter what you do. The best and easiest solution is to get the gantry size right in the first place. Extrusions are convenient but they are difficult to square and the slots are not efficient for local stiffness of a connection compared to a std tube or section. Plus all the small free edges vibrate like crazy, I have done FEA modal analysis to understand this and extrusions are very live in terms of harmonic excitement. Pick your poison as the saying goes...
    UCB -- I agree with Wizard that the columns need thinking through. In a fixed gantry design the columns are one critical element and all effort must be made for these to be Uber stiff and true. The flanges need to be thicker to allow for a machining allowance, minimise welding distortion (consider silver brazing or bronze brazing, far less distortion, torch or TIG) and to improve the local stiffness. The connection to the base plate is complicated and will require machining in two directions (and jigging) to get it flat and true and pull up in two directions. If you are to weld these things then using side plates is poor practice, a correct mitre is stiffer and easier to implement. Since you are welding & machining the columns you may as well integrate the gantry as well. The less bolts the more rigid it is but it will need to be finish machined. Welcome to the shark tank... Peter
    Jul 2012
    102
    I agree that filling an aluminium 80/20 extrusion is pointless (for stiffness). I was talking about standard aluminium/steel hollow tubing.
    Young modulus of proper epoxy-granite is 30-35Gpa.
    But if you compare a round vs square tubing of the same weight and wall thickness, the round one is always torsionally stiffer.
    However my point was not round vs square, rather than a hollow tube torsional stiffness can be massively improved with bracing or filling.
    Jul 2018
    6325
    Hi Jack - I doubt filling a tube can "massively" improve torsional stiffness please provide a calculation to support the claim. The only way to massively improve it is to make it bigger as its inertia is a function of its size to the 4th power. Whereas filling it is a linear (based on material stiffness) and a decreasing geometric inertia equation as the material is inward vs outward addition. Unless you use materials like steel (200GPa) beryllium 278MPa or VHM carbon fibre 600GPa to fill a tube correctly you will get a modest improvement. but its not worth the effort when a tube 20% bigger will be twice as stiff 1.5x bigger will be 6x times as stiff (now that's a difference maybe in the massive range)
    In the application of a gantry we are not interested in same weight and wall thickness elements. We require the most rigid solution in a given envelope. That solution includes allowance for threads and parts. The gantry is in "air" and on a machine its size is rarely a driver for other things so BIG IS BEAUTIFUL and it's all win win. Peter
    To check my opinion I've attached a calc for a steel tube and an al tube 100x100x6 filled with epoxy granite. The steel tube improved 3% in rigidity and the Al improved 7%. A costly exercise for little gain? Check my maths please...
    Jul 2012
    102
    If I'm not mistaken you are calculating the bending stiffness, not the torsional stiffness.
    @dmalicky did extensive analysis with various cases to optimise a gantry tube. Here's the thread for reference: https://www.cnczone.com/forums/diy-c...d-posts-4.html
    I also did some basic FEA on a small mill I'm building. Overall stiffness improved by 40% just by adding some bracing inside the tube (a 1m 260x180x12.5mm steel tube).
    (Following FEAs are with a 1000N force at the cutter, the only thing changed between the two is the added bracing.)
    Attachment 427454
    Attachment 427456
    Jul 2019
    8
    Thanks again for more feedback!
    Wizard - I really like the idea of flipping the table, and swapping the rail/carriage sides. Any ideas on how then to mount the carriages to the surface plate? I'm afraid running bolts up from below will be out of the question, but maybe mount the carriages to larger Aluminum blocks and that to the surface plate? I'll have to space it out anyway to make room for the ballscrew, so I can used the spacers to actually mount the carriage to the plate. As for spacers 5/8 is nearly on the money for what I would need to raise the table by, and I can get "precision machined" stock off ebay pretty cheap. I've mocked up what I think you're getting at in Fusion, although it's a bit of a rough WAG. I may have to look into getting a longer base to accommodate the rails, and figure something out for mounting the floating ballscrew bearing.
    I also wasn't an enormous fan of how the uprights were mounted, but I suppose I hadn't considered rotating the system, as I believed that would limit my travel (aiming for 12" x 24" or workable area.) I was planning on using 3/8" plate for the top and bottom mounting surfaces. In all likely hood I would almost certainly encounter warping issues with how much heat would need to be applied to weld it. On the other hand that would give me quite a bit of meat to work with should I elect to have it machined.
    In terms of expectations, the surface plate base may betray my accuracy/repeatability expectations somewhat. The ballscrews themselves are C7 grade, which may leave something to be desired in terms of what would be achievable with a 200lb cast iron base, but will satisfy my requirements without issue. If I'm able to get within several thousandths over the travel length of the machine I'll be very happy. Lets say 0.005 being the max allowable error per foot of travel.
    As for the gantry I think I'll go with a steel gantry. I can get just about any size hollow structural steel relatively cheaply around here and after talking to a few machine shops I should be able to have it faced for a reasonable price. When it comes to having all of the mating surfaces machined is there anything inherently wrong with, assuming minimal warpage, shimming into alignment, and using bolts to fasten it together? It would cut down on machining cost, and complexity at the expense of lots of extra time in setup. Alternatively I could also buy a long piece of pre-machined 5/8 Aluminum and mount the rails/sliders/etc to that and bolt that to the gantry.
    Jul 2019
    8
    Got the rest of the model updated. As it stands I should easily have 12" of usable machine area in the x axis, just a hair under 24" in the Y, and around 5" in the Z
    I may consider taking a page out of ToT's book and weld the X axis bridge to the uprights, using a nut and bolt to bring it as close to square as I can. Anything left I can shim out under the upright supports, and finally pinning it when I get it just right. As for mounting the ballscrew underneath the bridge I could work something out, but it would likely take away Z axis height. If you think mounting the screw on the top will be a serious issue I could probably fit it between the rails if need be.
    More parts have rolled in, including the rails and ballscrews. I have to say I'm reasonably impressed with the quality given the low price point. I cleaned everything up with some alcohol and for the time gave the carriages a coat of light oil. I was expecting to see some machining debris in the carriages, but after painstakingly disassembling 2 of them and cleaning them over a white towel in an old pan I found very little if any, just a light coating of what looked to be a thin lithium grease. The ballscrew ends needed a bit of light sanding to fit in the bearings, but everything else fit nicely. As expected there were 2 6001 sealed bearings in the fixed end blocks, which I'll swap for some 7001's when I get the chance. The carriages all seem to have a light preload on them even after cleaning and oiling with 3 in 1.
    Here's a picture of the surface plate. There's a couple nicks and gouges, but nothing proud of the surface, as well as some small scratches. Probably not the precision plate it once was, but it'll serve it's new purpose well.
    Jul 2018
    6325
    Hello Jack - I used Izz so did compare torsional rigidity. Adding the internal brace stops the section from lozenging. This is a different approach then filling with epoxy. Adding the brace correctly in practice is quite a mission. I've done the same FEA work in the Maximus thread if you look that up. There is a critical tube thickness where this lozenging becomes acceptable. By acceptable I mean within the deflection target you set. So if you take the brace material and distribute it to the tube you may end up with an acceptable design. Plus adding a brace like you have makes the structure asymmetric so the deflection maybe different if you push in the other direction (so check this) . Since you are welding extra bits on for the rails I suggest you move the rails into the same plane as the top and bottom flanges. This will also minimise lozenging as the loads go directly into the flanges.
    1000N and 0.055mm deflection is a static stiffness of 18N/um this is very stiff for a little machine. Seeing you have modelled it as a bonded structure I'd expect it to be about 50% efficient considering bolts and bearing compliance. So say 9N/um stiffness at the tool. This is a good figure to achieve for a small mill.
    1000N for 0.038mm is 26N/um so maybe 13N/um in reality. If you achieve this it will be a very good little mill. You have the tools so keep going. When you build it check its static stiffness to the model that will give you an efficiency for future work. With lozenging and some of these effects linear solvers do not correctly predict the deflection. You need to do a non-linear run to confirm no non linear effects are present in the structure. I have found making the cars aluminium vs steel stiffness makes them nearly the correct compliance. I discuss bearing stiffness/compliance in the Maximus thread if your interested. A typical VMC is 150N/um as a comparison. A small cheap benchtop mill maybe 5N/um but generally less. Peter
    As an afterthought the ends of your gantry are open, if you close them you will improve again maybe won't need the brace.
    UCB this is same for your design, close the ends of the gantry. Open ended sections are not very stiff. Cheers Peter
    Jul 2012
    102
    Peter, thanks, "lozenging" was the word I was missing.
    The amount of engineering effort you put in your Maximus design is impressive, I'll read the whole thread later.
    In my simulations EG filling is even more effective than the partial bracing, and it also provides the much needed vibration damping - a hollow steel tube rings like a bell.
    Closing the ends is better than nothing, but much less effective than filling to prevent the lozenging.
    So I believe my initial point still stands: filling the gantry tube with EG is an easy way to stabilise the cross-section with the added advantage of vibration damping, especially in a fixed gantry setting where the extra weight does not matter.
Page 1 of 2 12
  1. Fixed Gantry CNC build log
    By shoot in forum DIY CNC Router Table Machines
    Last Post: 09-13-2019, 10:22 PM
  2. Fixed Gantry Birch Ply Build
    By Browellr in forum CNC Wood Router Project Log
    Last Post: 01-27-2017, 12:33 AM
  3. New fixed gantry build looking for comments or suggestions
    By ahacking in forum DIY CNC Router Table Machines
    Last Post: 06-14-2016, 10:15 AM
  4. New DYI Fixed Gantry Router Build
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 07-06-2015, 12:45 PM
  5. Fixed Gantry - First Build
    By Schweeb in forum DIY CNC Router Table Machines
    Last Post: 04-01-2012, 10:49 PM
