585,994 active members*
4,834 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Help with servo suggestions
    Sep 2019
    54
    Hi all
    I brought a esab table
    With servo motor- gearboxes
    The controls is too old, still working on floppy disc,
    I have Mach 3 and stepper motors on our own table,
    Could I put Mach 3 onto the esab table and use the existing servo motor-gearboxes.
    It would be good if I could as these are good strong heavy gearboxes,
    I just don't know anything about servo and what is needed to drive them,
    The motors on esab table are,,
    SCT
    type. M642/T
    NR 9804735
    M642-1340-1208-07 TPZ
    004.639.093 X 0PZ
    Datum 1998
    Anything else I would need to find out if these motors would work
    Dec 2013
    5717
    Re: Help with servo suggestions
    I'm not able to find any information on the motor you list.
    If you want to use Mach3 then I would replace the servo motors and drives with modern hardware that has the correct form factor and specs. DMM Tech servos would be my first choice. https://store.dmm-tech.com/
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2019
    54
    Hi Jim
    Ok will check them out,
    My other main concern is HF interference
    The cutting source is a HT 2000 HYPERTHERM
    I have been told by hypertherm there strong HF
    could destroy standard pc computer
    But not sure if this HF could be blocked in any way from the computer
    Dec 2013
    5717
    Quote Originally Posted by Dem1 View Post
    Hi Jim
    The HF interference generated by a plasma torch is a concern. Proper grounding, filtering, cable shielding, and cable separation is especially important when wiring up a CNC plasma. I managed to successfully do it with much less than ideal components, but I wouldn't send that system out the door for a customer, it was OK for my in-house use.
    Wired properly, my opinion is that a standard PC will be just fine. Optical isolation is your friend. Reusing the original control cabinet, filtering, and cabling might be a great idea. Take special note of how it was originally protected and grounded.
    Jim Dawson
    Sandy, Oregon, USA
  1. RSF linear encoder DC servo motor suggestions
    By johndmcmaster in forum Servo Motors / Drives
    Last Post: 12-27-2023, 04:03 AM
  2. Suggestions for low-voltage high-resolution servo
    By Storen in forum Servo Motors / Drives
    Last Post: 09-02-2018, 11:50 PM
  3. Replies: 1
    Last Post: 08-28-2018, 01:05 PM
  4. Replies: 10
    Last Post: 10-19-2017, 07:17 PM
  5. Servo's and noise suggestions
    By ty1295 in forum CNC Machine Related Electronics
    Last Post: 11-09-2004, 02:59 PM
