585,996 active members*
3,850 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Syncing/Squaring Gantry Mach3 Settings?
Results 1 to 6 of 6
    Dec 2005
    258
    Finishing up my 4848. I am having probs with syncing/squaring up the gantry.
    A is slaved to Y.
    If I don't select "Home with Slave" when homing the motors spin opposite.
    When Jogging they work as expected.
    Prob with Home with slave is they only use one of the two proxy switches and don't square the gantry individually.
    Do I need to remove "reverse" A in homing and limits on my slave axis and reverse A wiring. What settings do I need to have set?
    I am getting so much conflicting info from google search.
    BTW I have edited the Ref Home script already to home Y and A together "Refcombination (10) which helped my current settings. Do I need to change this back?
    TIA
    Feb 2005
    829
    Re: Syncing/Squaring Gantry Mach3 Settings?
    Sounds like you have your positive and negative homing setup wrong on your A axis. If your motors work fine while jogging that means the motors are wired correctly.
    On your homing and limits screen look for "HOME NEG" and the settings for your Y and A axis.
    Feb 2005
    829
    oop double
    Try "Home Neg" on the one that moves the wrong way?
    Dec 2005
    258
    This is my current settings...
    Both Y and Slave Y(A) are wired the same to the controller.
    I originally assumed reversing it in Mach3 wouldn't present an issue down the road, I might have been wrong.
    Thanks for any help,
    Eric
    Y and A should have the same "Home Negative" setting. Did you always have them different?
  1. squaring gantry
    By connie1 in forum Avid CNC
    Last Post: 05-31-2019, 01:26 PM
  2. Squaring the x axis gantry
    By Kris-K2 in forum Commercial CNC Wood Routers
    Last Post: 11-26-2017, 01:36 PM
  3. Gantry squaring questions?
    By FelixPQ in forum DIY CNC Router Table Machines
    Last Post: 03-08-2016, 08:28 PM
  4. Squaring the Gantry to the X-axis
    By expo123 in forum Avid CNC
    Last Post: 11-09-2013, 01:25 PM
  5. Squaring the gantry
    By bradbergemann in forum Excitech routers
    Last Post: 01-07-2010, 02:31 PM
