585,708 active members*
3,640 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Chinese Ebay 4th axis Harmonic Drive
Page 1 of 2 12
Results 1 to 20 of 23
    Sep 2018
    34
    Question Chinese Ebay 4th axis Harmonic Drive
    Hello!
    I have just received the harmonic drive. I read before and I was aspecting a gapless drive, with no backlash. Now I ma new to harmonic drive but if I try to move the chuck by hand it has a play of like 4mm back and forth. Does it come from the harmonic drive or it something else? How can I get rid of it? I do not find anyone else with a similar problem.
    Here the video showing the problem https://www.youtube.com/watch?v=uSB-UlZzBjQ
    This is the type of harmonic drive. I have the 1:50 reduciton.
    https://www.ebay.de/itm/3-Jaw-K11-10...8AAOSwJTNbvW2H
    Thanks a lot! I need it to make helical gear and like that won't work :-(
    Jul 2010
    180
    Re: Chinese Ebay 4th axis Harmonic Drive
    OMG I must be bored...
    Apart from that thing is a complete toy, does the motor shaft move in conjunction with the chuck. What you are looking for is the difference of movement between the two,, this is your backlash. If no backlash either put some more current into the stepper motor or get a bigger one with better holding torque.
    Sep 2018
    34
    I need for making small gear, it doens't have to go through heavy cuts. Based on what also reported in this forum this style of harmonic drive should have almost zero backlash. That why I wanted to try.
    Anyhow the motor is not moving, you have back and forth play only in front. That's why I coaaled backlash.
    Jul 2010
    180
    I would actually be amazed if this is a harmonic drive... However, even a worm drive or direct drive shouldn't move like that. Something is wrong.
    I think your options are send it back or pull it apart. Good luck!
    Sep 2018
    34
    Quote Originally Posted by FastFarmer View Post
    Others with this cheap harmoninc drive didn't mentioned such degree of freedom, they actually stated almost zero backlash. I think I got a fautly one. So lucky. I guess I will try to see if the seller can check other dirves at the factory if they all "feature" this fantastic backlash otherwise I will try to solve it, but not sure how since it's not a simple gear drive.
    Sep 2018
    34
    I pull itll it apart. The back lash is really from the harmonic drive. Now I do not know if I got a fautly one or if this type are all like this one
    https://youtu.be/qgmcX7lL5zw
    Jun 2010
    4256
    Good lord.
    Well, if it is an HD (and it seems to be), then the unit as a whole has a serious defect, and should be returned.
    But then, one asks why.
    One possibility is that the flexspline, which is the heart of the unit, is really seriously worn out. Just how this could happen, I do not know, and if it did happen I would expect the whole thing to collapse.
    Another possibility is that the outer part of the wave generator has been worn out and is far smaller than it should be. Same comments.
    Another possibility is that something is actually missing or is of the wrong size. This seems like a possibility, as the bit on the stepper motor did not look as though it had any bearings. I note that you are able to push the motor drive back in place fairly easily: this should not be possible they way you did it, except with great care and skill. I would prefer to say it looks wrong. And when you wobbled the front end, I could see the flexspine wobbling back and forth.
    Underlying all this is the question of how could the thing backlash like that. It could be that the spline is not fully engaging with the outer teeth, but is instead able to rattle from side to side - like rattling poorly engaged gear teeth in a conventional gearbox. This would be consistent with a missing or wrong-sized part.
    Have a look at the attached picture (from HD catalog). Does the drive bit look like this, with either balls or rods as bearing elements? Some detailed close-up still pics would be more useful now than videos.
    Incidentally, that unit is a 14-50 one according to the label on top: the smallest in the whole range. It has a rather large chuck mounted on it. In my book, the chuck is a bit big for the bearing.
    Cheers
    Roger
    Sep 2018
    34
    Quote Originally Posted by RCaffin View Post
    Good lord.
    The teeth on the flex spline are really small, I also thought they look worn out but then it's a new drive so I thought it must be normal to allow the teeth to disengaged when rotating.
    That what I think as well, to me there is too much gap between the flexspline and the circular spline, so the flex spile has to deform too much before properly engaged the circular spline.
    Exactly, that what I think as well
    Yes attached to the stepper there is the wave generator, the part where I was putting back in place the C-clip. This part also looks like a bit too small. I would aspect way more compressor from it to the flex spline.
    Cheers
    Roger
    In bolted the reply to your thoughts. I think the only solution is returned. Still have to understand if I got a faulty unit or they are all like that.
    Thanks for the help!
    Aug 2019
    339
    Quote Originally Posted by rey8801 View Post
    To my knowledge you do not need backlash management for cutting gears; one-way continuous rotations. As long as it index accurately you'll be making great parts with this tool. Small parts, but still great.
    You were looking for a dividing head btw. Rotaries meant for machining gears needs lock/unlock capabilities
    edit: ignore my first sentence. I've just watched the first min of your vid. You will not be able to cut gears with this. That's not called backlash anymore, it's called free-play. yikes. Case for Return & Refund/Replace, your unit is unusable unfortunately. Worst scenario disassembly and complete rebuilt required. Sorry friend
    Sep 2018
    34
    Quote Originally Posted by Mecanix View Post
    Continuous cutting can be a solution in some case but forgot to mentioned, with gears I mean duoble helical gears and not simple spur gears. So I need the 4th axis to be able to move with a decent precision. THe holding torque of an harmonic drive is really good. Even in this one is locked in place. The problem that in this drive you have the backash first and then it locks, whihc makes it unusable for what I want to do.
    Aug 2019
    339
    Return the unit. Get a replacement.
    Jul 2010
    180
    Hahaha. You make me laugh...
    Jun 2010
    4256
    Hi Rey8801
    While you are at it, you might like to read this stream:
    Build Thread The Design and Construction of a 'Backlash-Free' Rotary Table
    It is about a rotary unit I built using a larger HD unit. I got into some detail about calibration and measurements.
    Cheers
    Roger
    Sep 2018
    34
    yeh I am now asking all the shops selling this type if they can check their unit and see if they have the same problem. I hope by getting the reply from different sources will lead to the truth! Thanks guys. I will for sure return my "free play HD" ahahah
    Aug 2019
    339
    Just show them the vid you shown us, its pretty obvious this shouldn't have shipped out at the first place. Sorry it came to you that way... f n frustrating to watch in fact.
    G'luck man.
    Sep 2018
    34
    I will report her eback if I get it solved somehow. Thx
    Mar 2012
    74
    I have the same 4th axis long time ago ~4 years. Also have this problem when just bought, but not as serious as yours. The manufacturer uses old harmonic drive in it...
    Sep 2018
    34
    I think that was the problem. Now I am getting a replacement and by the video the supplier sent me there is not play anymore. Fingers crossed
    Jun 2010
    4256
    Interesting. Criticism of 'Asian rubbish' is easy to make, but I have found that a lot of (ebay) vendors are actually quite concerned about keeping their customers happy. There have been a couple of exceptions, but some of the others have been very good with reliable stuff. CarbideChiu on ebay has given me very good service over the years.
    Cheers
    Roger
    Jul 2010
    180
    Well, it's not so much being Asian rubbish... but more that we are talking about a toy... and a cheap toy at that. Try buying a small Haas rotary and see how many thousands you will have to pay.
Page 1 of 2 12
  1. Holding brake needed on a 4/5th axis when using a harmonic drive?
    By shinji2k in forum Linear and Rotary Motion
    Last Post: 10-16-2019, 03:44 AM
  2. Is a Harmonic Drive best solution for a 4th axis?
    By bogiestl in forum Benchtop Machines
    Last Post: 09-23-2019, 06:49 PM
  3. Help! Harmonic Drive 4th Axis Troubles
    By BanduraMaker in forum Linear and Rotary Motion
    Last Post: 12-22-2016, 11:06 AM
  4. Harmonic Drive 4th axis - PEU
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 04-27-2014, 04:33 AM
  5. Harmonic drive 4th axis for the X2
    By scubaben in forum Benchtop Machines
    Last Post: 03-04-2012, 07:51 PM
